I have tried and tried, but I am unable to get exclusive audio out of 3.5 mm port and or usb-c wired headset. The headset works perfectly with any other unit. I have even tried the app “audio output” from Chum. Nothing works.
Scenario is when I put some audio on, it plays in speaker AND headset.
BT headset works like a charm. Any of you have the same scenario?
I’ve tried different sources. Browser spotify / di.fm and also Android apps. Pactl? Is it pulseaudio controller? Cant get the hang of whether it is controlled in a app or through terminal?
Thanks for the advices, but to clarify that my bumper (cover) has nothing to do with this. Is there someone who has been able to use the usb-c port for external headset without speaker on at the same time?
