on the proton vpn website i have found the linux version but now it asks me to manually add all this code in my terminal window, which i have tried many times before and it just doesnt work. It drives me insane.
now i have spend all day chatting here and i am still none the wiser. i am getting really tired. and depressed bc of this
Then we skip laptop, also please consider reinstalling windows as you wont have much fun with your pc if you cant use it properly and ask your son for every litte detail.
Take your phone and open the Browser app (the one with the top left icon from your first screenshot). is probably in browsers folder (not Brave, we need the one that just says âBrowserâ)
And then you can go into the the Settings App, then to VPN. There, choose to add a new VPN (maybe this option is in a pull-down-menu, so you need to tap on the screen and drag to the bottom for it to open).
In the new dialog that opens up, choose âWireGuardâ as the VPN-Type. This will show you two buttons. Choose the âImport fileâ (or whatever its called in your language) button. This gives you sort of a file picker dialog, just like on other smartphones. Go to âHome-Folderâ and âDownloadsâ (your file will probably be stored there, if you havenât chosen another location when you downloaded it). Click on the VPN-file you downloaded earlier. It will show you some settings with strange values. This is fine. Just click on âAcceptâ in the top right corner and you should be good to go!
If you encounter an error, just report it here but please with screenshots
(You might also consider this tutorial. Although its for another VPN-provider, just skip directly to âStep 2: Importing the file on Sailfishâ
It looks like your apps got sorted to folders. The shapes with numbers in them are folders, if you tap on them, you go into the folder and the apps are there
