HELP i don't understand this Jolla C2
i have posted here before but i dont undrrstand what anyone is talking about. i still have the same problems with my jolla.
i dont know where i can open my downloaded apps, i can only find them in settings under the app tab but i cant open them.
in the jolla store i cant download anything. i dont understand this phone and my old one is nearly dead so i really need to start using it.
i dont understand any of the suggestions ppl are giving me here cause i try do them but i get stuck straigjt away
i am desperate now. i need somebody to guide me and teach me
k
I sent a PM to help you :smiley:
I have moved it to the Get Started category :slight_smile:
Still not clear for me. Sounds an issue with Aurora Store.
anyone out there who has time to help me?
Does swipe from bottom edge show anything?
Did you run first time use help app?
Yes the previous guy who helped has determined i needed to tick a box in the aurora store app. i downloaded proton vpn succesfully whicj eas visoble in the app tray. but now it says i cant use proton vpn by downloading so can you help me set up vpn in anothrt way? I found the syandard jolla vpn option but i dont know how to get it so i usr proton vpm as i have a subscription with them
first, dont use android apps for this, you still trying to get vpn to work?
Jolla Store:
First you need to make an account if you havn’t already else you cant download/install apps from there
Right tab
Then you open the app grid (swip from bottom and open the store page)
then inside the app search for file manager
Open Pulldown menu to install
Browser:
Open Browser, down right open Settings, change search provider if you dont want to use google search (maybe you have to visit search provider website once before it shows in that menu, not sure):
Download files (I cant use proton vpn as example as i dont have an accouunt)
click file then select path
Then you’ll download the file to /home/defaultuser/Downloads folder
again dont use android apps for this
if you got the file in the download folder we can try setting up vpn
(if unsure you can try to make a screenshot maybe this helps understanding the issue)
yeah i dont get it. so are you saying i cant download android apps straight from any app store?
i have to download from a browser or THE pre-installed jolla browser?
or do i have to go into jolla store/filebrowser and then?
No. You can use Aurora store or others if you trust them.
In general it’s more likely to get help if you separate your issues into their own topic.
You can, but some Android apps are pointless to try to use within Android App Support.
VPN apps are one such case.
This is because things like Networking are handled by the Operating System, and the Operating System is Sailfish OS, not Android.
So in order to use a VPN setup, you must configure it in Sailfish OS.
No you can of course use also android apps, but then the file gets downloaded to the location where android download files are stored.
This complicates things.
Also if you dont want to use applications built for sailfish os, why buy such phone?
i still dont understand. so you are saying i cant download apps from any of the app stores, but i can download from the jolla store, the aurora store, droidify and f-droid? cause those are the app stores i use.
i went into the file browser but i dont know how to use it or what to do?
i still cant access any of the apps i downloaded before i checked the checkbox in aurora store. i dont even know how to uninstall tjem and try again?
i do want to use this phone, i just come from capitalist bastard samsung phone, i just dont understand how to afapt to this compleye alien tech. I know nothing dude, i am a noob with this. i cant deal with these parasitic companies anymorr, hemce why i jave to learn
Maybe this helps you to understand better, sorry for bad drawing:
| Sail     |
| fish     |
| VPN      |
|     | An |
|     | dr |
|     | oi |
|     | d  |
Your Android stuff is inside sailfish, so you cant manipulate VPN from within android.
You can use android apps (aurora, fdroid, play store, i dont know) and apps built for sailfish (those wont run on android) like the mentioned file browser or all the apps installed by default
okay, so can you help me, guide me through that process? i understand i have to go into filebrowser. i am in there, then what?
Some stores offer option to just download the apps. But if you use app stores, what is the point to only download them but not install them?
I almost never use only download I just install them so I don’t know for each of them.
I don’t understand. Please post your screenshots (by pressing volume up and down button at the same time). That way we’ll probably understand where did you stuck.
And I didn’t understand if apps shows if you do a bottom swipe?
Did you already download the needed vpn configuration file? (you can also use your pc and copy the file to the phone)
i dont understand what youre saying. this is the problem:
i can only see my downloaded apps in settings/apps because i have downloaded android apps ??
those apps i cannot see in the app drawer (swiping up from the bottom of the screen)
i dont know how to get rid of them all and download & install them correctly.
i dont know which apps are android and which arent, or are you saying i cant download straight from any app store? i have lots of subscriptions, like proton, which i want to continue on this phone, like proton vpn, so how do i uninstall the wrong downloafs, and do it so i can correctly use them?
lile i said, i dont know how to use this filebrowser
