Gigaset GS5 Pro not regular GS5 possibility to flash Sailfish OS
As the title says i would like to know about Gigaset GS5 Pro not regular GS5 possibility to flash Sailfish OS
Thanks in advance
Check the forum for community builds
No info about this specific model. That’s why i asked :slight_smile:
How big are the differences between GS5 Pro and GS5?
And did I understand correctly, that there is a port for the GS5 available? If its still maintained you could ask the porter how high are the chances the GS5-port would work on GS5 Pro.
The Volla 22 (Gigaset GS5) Thread - Hardware Adaptation - Sailfish OS Forum
If the specs are the same, then why not? If they are I doubt it would work
I installed Sailfish on a Rephone using the UBports installer. The Rephone is probably equivalent to the GS5 Pro.
Can you choose sailfish on Ubuntu installer?
No, and my Rephone with Sailfish did work ok, but with low performance. A better community choice is oneplus 6. Even better as some official ports.
It’s been over a year (November 2024) since I removed stock Android from my Rephone.
With the UB-Ports installer at the time, you had to select Volla Phone 22, and then you could choose between Ubuntu, Volla OS, and Sailfish for the installation. Ultimately, I switched from Sailfish to Volla OS.
