Foreca Weather Invalid Authentication credentials
Foreca,
Message : Invalid Authentication credentials
Always 24 Celcius and Clear
Location is turned on
(High Accuracy positioning)
Re-installed the app Foreca,
didnot solve the issue
Search before posting.
We’re turning into the weather forum
Good thing I maintain a weather app and contribute to another! Time for a major upgrade!
Well I wouldnt complain about 24 celsius and clear…
Searched with google : no results
On the forum.
Is the weather app not working any more
@dutchsurfer: tl;dr: install Meecast instead. It’s a superior app anyhow (you can choose weather providers).
And it’s also in chum and openrepos!
Only drawback: no intraday forecast in eventsview
Thank you !!!
Solved the issue.
(by the way : Search mostly with Qwant.com)
Is there a chance the hourly forcast for the day to be added?
I am not the developper, I have no Idea. I guess it would be a massive amount of work.
Maybe I misunderstand the question from @shults, but there is an hourly (every 3 hours, not per hour) view of weather in eventsview. Just tap on the daily forecast (default) and it changes to “hourly” forecast.
@davidrasch, it’s probably not too difficult to change to hourly (literally every hour) but I think this would be making too many “calls” to Foreca’s API, putting the user/Jolla over the free daily calls.
Sorry, this was meant to adress possible implementation of hourly forecast in Meecast in Eventsview.
The Weather is no working anymore
My weather also broke yesterday evening. Strange white crumbs started to fall from the sky and rendered the streets unusable
