crun
1
REPRODUCIBILITY: 100%
OS VERSION: 4.5.0.18
HARDWARE: X10iii
UI LANGUAGE: Eng
REGRESSION: yes
Flightmode disables GPS.
GPS icon remains on. see also
On Android X10iii, GPS still works as expected in flightmode.
This is also a silent fault as the gps icon stays on. and gpsinfo lets you activate/deactivate the gps even though it is disabled by flight mode
- GPSInfo running, locked
- Set flightmode
- gps stops updating.
phklrz
2
Confirmed on my Xperia 10 III and on my XA2 Plus. It is a regression to 4.4.
Thank you for your bug report. May I ask you to update the regression section and write yes?
Confirm that behavior on Xperia 10 / 4.5.0.18. But GPS works on restarting it manually (off/on in upper menu) while staying in flight mode.
vige
6
Copied to internal tracker. A kind request for future bug reports: Please fill out all the fields if at all possible. It makes our work easier.
