BUILD ID = OS VERSION (Settings > About product): 4.1.0.24
HARDWARE (XA2, Xperia 10…): Xperia XA2
UI LANGUAGE: Spanish
REGRESSION: (compared to previous public release: Yes, No, ?): I think this issue happened to me since I updated SailfishOS to 4.1.0
Gps icon continues to appear after disabling location whenever I use an app with gps. It doesn’t matter if the app is android or native
no
Enable location
Open gps app (for example, PureMaps)
Gps icon appears in top bar
Close gps app
Disable location
Gps icon is still in top bar
Gps icon souldn’t appear in top bar after disabling location
gpstoggle --help
SailfishKeyProvider_ini_read_multiple: reached end of file
gpstoggle v0.0.1 by halftux
Options:
[--help] help output
[location=0] toggle location permission 0/1
[power=0] toggle gps chip power 0/1
Ok, I think I know what the problem was. A geoclue process was running and it didn’t close when I turned off gps toggle. Since I closed this process manually, this issue disappared. Anyway I don’t understand why a restart of my phone wasn’t enough to solve it. At the moment, everything seems to work fine. @amaretzek, thank you for your answer, it is good to know that tool to manage gps toggle from Terminal.
