Fingerprint record lost randomly
Same issue here, since when I started with the Suomenlina version and now the Vanha Rauma version (4.4.0.58). I use the paid version on a Xperia 10 ii.
It just happened on my Xperia 10 III as well. The button in utilities is really quite handy.
same on >> Xperia 10 II + OS 4.4.0.64
This has happened to me two times already, both of the times are with the latest OS at that time.
Last time was today, with 4.4.0.68. And after losing the fingerprint pattern, I can’t record a second finger because I am greeted with a message “Virhe! Sormenjälkeäsi ei tunnistettu”. I didn’t even touch the sensor.
I found a way to log oom kills by watching dmesg while browsing a heavy web site using the Browser:
dmesg -w | egrep "lowmemorykiller|oom_reaper|^ {19}.*"
Using that I get output like this:
[140539.580703] lowmemorykiller: Killing 'ec_fdroid:tab21' (22126), adj 905,
                   to free 85860kB on behalf of 'HwBinder:3801_1' (23173) because
                   cache 475268kB is below limit 668640kB for oom_score_adj 0
                   Free memory is 647552kB above reserved.
                   Free CMA is 0kB
                   Total reserve is 136256kB
                   Total free pages is 71000kB
                   Total file cache is 553396kB
                   Slab Reclaimable is 123100kB
                   Slab UnReclaimable is 417072kB
                   Total Slab is 540172kB
                   GFP mask is 0x6280c2
                   Kernel Memory Reclaimable is 13556kB
                   Free Swap 699252kB
                   queue len is 1 of max 1 reason:0x2 margin:-16314
[140539.581611] lowmemorykiller: Killing 'AndroidUI' (22051), adj 900,
                   to free 148920kB on behalf of 'HwBinder:3801_1' (23173) because
                   Free CMA is 0kB
                   Free Swap 699252kB
[140539.587560] lowmemorykiller: Killing 'com.whatsapp' (23989), adj 104,
                   to free 78024kB on behalf of 'HwBinder:3801_1' (23173) because
                   cache 474812kB is below limit 668640kB for oom_score_adj 0
                   Free memory is 656144kB above reserved.
                   Free CMA is 0kB
                   Total free pages is 80104kB
                   Total file cache is 552940kB
                   Free Swap 698740kB
                   queue len is 1 of max 1 reason:0x2 margin:-14038
[140539.591645] lowmemorykiller: Killing 'jolla-email' (31314), adj 103,
                   to free 137720kB on behalf of 'lipstick' (5980) because
                   cache 474132kB is below limit 668640kB for oom_score_adj 0
                   Free memory is 658960kB above reserved.
                   Free CMA is 0kB
                   Total free pages is 83632kB
                   Total file cache is 552256kB
                   GFP mask is 0x6000c0
                   Kernel Memory Reclaimable is 13100kB
                   Free Swap 698484kB
                   queue len is 1 of max 1 reason:0x2 margin:-13156
[140539.594922] oom_reaper: reaped process 22126 (ec_fdroid:tab21), now anon-rss:0kB, file-rss:0kB, shmem-rss:24kB
[140539.623615] oom_reaper: reaped process 31314 (jolla-email), now anon-rss:0kB, file-rss:0kB, shmem-rss:84kB
[140539.646406] oom_reaper: reaped process 23989 (com.whatsapp), now anon-rss:0kB, file-rss:0kB, shmem-rss:2780kB
[140539.681563] oom_reaper: reaped process 22051 (AndroidUI), now anon-rss:0kB, file-rss:128kB, shmem-rss:760kB
The good thing is that I can now see every OOM kill. The bad thing is that it’s very frequent… It’s a few kills per minute, give or take.
Edit: This is pretty much offtopic, so I started a new thread instead.
My SailfishOS 4.4.0.68 running on Xperia 10 III just lost the saved fingerprint for the third time - again, after about a week…
I don’t know whether it is the same problem as described, because no fingerprint is shown in the settings page after the act:
It is very annoying.
I have to say I haven’t lost a fp once yet.
Using 10mk3 for 2 months.
I lost it once, but reboot helped, and all were back.
But I can imagine how awful it must be for others
It’s been mentioned in this thread already, but just as a reminder, there’s now a button in the Settings app (Settings > System > Utilities > Restart fingerprint service) that will restart the fingerprint daemon and should bring the sensor back to life.
While this is a workaround rather than a fix, if you do discover your fingerprints aren’t being recognised, please give this a go. There shouldn’t be any need to re-register your prints or reboot your device.
I haven’t had the fingerprints missing once since I adjusted the minfree values; before that it was about once every two days in my normal device use. I’m quite confident at this point that oom was the cause all along.
BUG seems still present on a freshly flashed Xperia 10 II with latest 5.0.0.67
Where do you configure that and how did you adjust it please?
Coulf that be the reason my sshd never runs despite being ‘enabled’?
How did you check that? sshd is started via systemd socket activation, it is normal that it is not running when no session is active.
For the same reason it’s very very unlikely that oom or fingerprints have anything to do with sshd.
The changes were released for Sony Xperia 10 III so if your device is updates, you should have them already.
