Installing SailFish Utilities from Jolla store we have the chance to restart the fingerprint system when it does not work properly. Some days, it happens often.
I am suggeting to add an icon to restart the fingerprint reader on the lockscreen.
Obviously, fixing the problem is the main way but a quick workaround would mitigate the issue until it wil be investigated and understood.
A fingerprint sleeping issue?
Another way to deal with this issue is to start-reset-stop the fingerprint reader only when necessary:
lockscreen to unlock
add a new fingerprint
and keep running/ready the rest of the system (software stack) as far as possible.
At the moment, I set the energy saving mode at 100% of battery threshold: always. The fingerprint system fails a lot more of times. Possibly, the fingerprint reader will go to sleep when is not used for a long time and missing to wake up it, brings the system to a failure. Therefore, there is a good chance to solve the problem switching-on the fingerprint reader when it is going to be used and switching-off it when it is not.
there should be a setting for this.
cause if the user manually stops the fingerprint reader (for border crossing, for example), it shouldn’t restart the service.
If someone is going to crossing a border, entering or exiting between a hostile / unsecure country. The best s/he can do is to remove the fingerprint via the specific menu into Settings:System and rely only on a long-enough PIN with limited tries.
Question: what happens when the max numbers of tries has been reached without inserting the right PIN? Someone ever tried it?
IMHO, the SailFish OS currently lacks of many features for being used as a secure personal device in a hostile real-world enviroment. Privacy - intended as a protection for mass surveillance and unprofessional stalking - it is just a small subset of the security one needs to keep safe life-depending assets or data.
Then something crashes for any reason and the system restartsÂą with the fingerprint reader activated but not the icon to restart it in the lockscreen. Threfore you think that everything is fine but it is not.
Security and safety is about restricting the chances of a negative evet not increasing the options for no reason. The option you are asking is a completely another feature, like:
possibility to enchrypt the fingerprints with the PIN code in order to store them for a future use but the stored fingerprints should be displayed with a lock otherwise the user might forget that s/he has encrypted and stored. This might arise the possibility to rename the fingerprints not just enumerate them².
I know you did not forget anything in your life, not the used toothbrush in a hotel room but those escape for their lives tends to overlook, forget and leave behind a lot of things…
NOTES
Âą you did well, hiding the icon and shut-down the fingerprint but just before locking the screen, something goes wrong and you decide to restart the UI without the knowlegde that such action will restart also the fingerprint reader system because an updated you did recently changed that part and you did not noticed yet. Plus more other corner cases, etc. etc.
² a feature that can be good or bad, depending if cutting a finger to your son/daughter in another city and sending it to the border is an option…
The fingerprint reader suspending/awakening investigation goes much further and here you will find the analasys about it, updated at the time of writing:
It is easy to pretend to have forgot a PIN but it is not so easy to refuse to put your finger on the reader. The quick solution is to reboot the phone because the LUKs engine requires the code and in such a state the data are not yet uncyphered. Thus, any action will be - in theory - useless without knowing the PIN and at that time a maximun number of tryies before safely erase the LUKs key will be a nice feature to have.
I answer one question, I am doing a question: what’s happen when the max number of tries has been exhausted in the lockscreen PIN reader? Does someone tried it?
Thanks, I see.
Recalls me the bouble boot I had on the N900.
When you just pressed the power button:
-Black screen, small vibe + blue led for some seconds, then boot on an empty user. Encrypted home locked.
-Black screen, small vibe + blue led for some seconds. If you opened tje keyboard and typed your luks key, it opened the encrypted home and booted on your real user.
This way, it was not even necessary to pretend anything in case of control.
Yes right, I had totally forgotten that.
To be perfectly paranoid-compatible, the phone should boot on the guest account by default, without unlocking the encrypted partition. It would boot on the real user’s home only after some manipulation during early boot.
But well…priorities.
That was interesting for the tech challenge and spy feeling, in a pre-GAFAM datasuck era (N900)
Not really useful in my case/country/situation nowadays, as the intrusion “risk” comes from inside the devices today.
