SYSTEM
OS VERSION: 4.5.0.19
HARDWARE: Xperia 10 II dual SIM
ANDROID SUPPORT: licenced and installed
UI LANGUAGE: English
APPROACH
Recently I set the enery saving mode at 100% of battery threshold which means always active:
Moreover, I dimmed the brightness of the screen to the minimum and I have installed and activated the Pure Black Backgrounds patch which it expected to save energy with OLED display which is the case. The display is set to sleep after 30 seconds.
DATA COLLECTED
The System Monitor was running since the begging and collecting data. Here a composition of what I found:
The high-resolution image is available for download from here.
SCENARIO
In the area highlighted, the smartphone was resting alone with no native nor Android application apparently running and with the Android Support active.
Despite this the activity about system processes were more intense that normal usage but despite this the battery discharge rate was less or about 1% which is a great achievement.
OBSERVATIONS
Counter sides effects: some sub-system was not working when the smartphone has been waked-up. In this specific case the Bluetooth. More often the fingerprints reader get asleep probably and should be reset.
There is a huge opportunity to extend the battery life leveraging the power save mode as far as all the hardware sub-system are awaken correctly and at expences of the response time because applications starting lag a bit.
In fact, I have installed and activated the Reduce settings app lag patch but this patch changes the visualisation of some SFOS native menu/app not the time of starting of an Android apps.
PROPOSAL
The START / STOP states for the Android Support are not enough because clicking on an Android app, also the Android Support starts automatically. It would be much better having an option to disable the Android Support to avoid that it can support any application without the express will of the user:
disabled, stopped- A.S. is not running and it will not start automatically
disabled, running- A.S. is put in a sleep state for which it results unavailable
enabled, stopped- A.S. behave like now starting when requested by an app
enabled, running- A.S. behave like now when it running giving the service
With these option the Android Support can be kept safely disabled but quickly to gives it service if the user need it. This will make the SailFish OS more reliable about Android apps background activities and more power energy saving.
