'Feels like' temperature shows '0'
BUILD ID: 3.4.0.22
HARDWARE: Jolla1
APPLICATION: Weather (sailfish-weather)
REGRESSION: minor, Yes
Feels like? temperature shows zero for any location
Weather app installed from Jolla Store
See first page of Weather application
Feels like temperature displayed
Screenshot_20201003_002
I have found the error that causes ā€˜feelsLikeTemperature’ to sit at zero
Line: 27 of ā€˜WeatherModel.qml’ - (/usr/lib/qt5/qml/Sailfish/Weather/WeatherModel.qml)
Original code:
            weather.feelsLikeTemperature = current.feelslikeTemp
New code:
            weather.feelsLikeTemperature = current.feelsLikeTemp
a lowercase ā€˜L’ in ā€˜like’ of current.feelslikeTemp should be uppercase
the ā€˜Feels like’ temperature is now showing correctly;
Screenshot_20201007_002
I have made this correction on 2 x Jolla1 devices and both are now working as expected.
Should I mark this as ā€˜Solved’ @jovirkku ?
Yikes! Thanks for the heads up, fixed now for the next release.
That sounds ok to me. However, we seem to be lacking the rules and convention for this now that there is no automatic status link from Bugzilla to Forum (TJC used to have it). ā€œSolvedā€ now and ā€œReleasedā€ when that time comes. [to-be-developed]
Hi @jpetrell & @jovirkku - thanks guys. Upon the remark from Joona, I will mark it ā€˜Solved’. Please also see my other bug post regarding duplicate locations in Sailfish Weather. There are quite a few, some work, some don’t and some give different forecasts for the same area?, strange…but true.
Somehow this still doesn’t work in 3.4.0.24. Or is it just me? Rebooted a couple of times, changed to different locations and no change. Opened the WeatherModel.qml, still uses current.feelslikeTemp instead of feelsLikeTemp.
Sounds like you are not saving your changes to your file, hence the spelling mistake has returned, if the page was saved after editing, there is little to no reason it should get undone.
Sorry, my bad, what I meant to say is I was expecting that this would be fixed in the next release (= 3.4.0.24) . I haven’t manually edited the file to fix it myself.
Ahh, gotcha. Yes, the fix will be applied in the next OS update after Pallas-YllƤstunturi as per the comment from @jpetrell
