Fresh install of Suomenlina 4.3.0.15 on Xperia 10. I’m having trouble bringing over some of my old apps from XA2, whether installing from OpenRepos or from the .rpm files. I don’t remember these dependencies being missing or messing up the install before, and my last fresh install was on a 10ii so everything was 64 bit and different. I’d love to get Pebble up and running again after fighting that battle on my XA2 so hard.
Any ideas? Are these available in a single package I can grab from somewhere? And how can I get fresh versions of Storeman or Warehouse working - they aren’t installing from my .rpm download from OpenRepos? Help appreciated!
defaultuser@Xperia10]$ rpm -i -v harbour-storeman-0.1.0-1.armv7hl.rpm
error: Failed dependencies:
libsolv.so.0 is needed by harbour-storeman-0.1.0-1.armv7hl
libsolv.so.0(SOLV_1.0) is needed by harbour-storeman-0.1.0-1.armv7hl
[defaultuser@Xperia10]$ rpm -i pebble-1.6-1.armv7hl.rpm
libQt5Bluetooth.so.5 is needed by pebble-1.6-1.armv7hl
libicudata.so.46 is needed by pebble-1.6-1.armv7hl
libicui18n.so.46 is needed by pebble-1.6-1.armv7hl
libicuuc.so.46 is needed by pebble-1.6-1.armv7hl
[defaultuser@Xperia10]$ rpm -i harbour-warehouse-0.3-22.armv7hl.rpm
libpackagekit-qt5.so.6 is needed by harbour-warehouse-0.3-22.armv7hl
harbour-warehouse <= 0.3 is obsoleted by (installed) store-client-1.3.4-1.5.1.jolla.armv7hl
The packages you’re trying to install are rather old. E.g. Storeman is now v2.11 while you’re trying to install v1.01, and warehouse I’s depracted for ages. Maybe fetch the current packages and try again?
Thanks! I did try manual installs but it still wasn’t working. On reflection I realized I was having trouble with the “store installer.” Installing from an installer is a new feature since I did my last full system install, and reading the notes it says it relies on OBS and may take a few days after a new release comes out to get all the necessary repos in order.
Fortunately they also listed a path to the actual, old school storeman installation files (i.e. not the ‘installer’.) That worked and I was able to install Rockpool and a range of other tools with all dependencies. My Pebble is now up and running with the Xperia 10.
