Exporting Contacts / People with vcardconverter doesn't work
Edit:
There is no bug here, at least for locally stored contacts.
The command just has to be executed as normal user with devel-su -p and not as root.
For remote contacts, the @nephros given below commands have to be used.
BUILD ID = OS VERSION (Settings > About product): 4.4.0.58, flashed (defaultuser) as well as upgraded (nemo)
HARDWARE (XA2, X10, X10 II, …): XA2 (others not tested)
UI LANGUAGE: EN UK
REGRESSION: (compared to previous public release: Yes, No, ?): Yes, seems that it used to work
DESCRIPTION: Contact export with
Contact export with:
devel-su -p vcardconverter --export contacts.vcf
Doesn’t work and returns an error message:
[W] unknown:0 - The ‘mergePresenceChanges’ option has not been configured - presence changes will only be reported via ContactManagerEngine::contactsPresenceChanged()
[D] unknown:0 - Exporting 0 contacts
[D] unknown:0 - Wrote 0 contacts
None
  1. Open a terminal
  2. Enter the command
Contacts would be exported in a text file
Not exporting, error message
Command comes from this cheat sheet. I tested on my Xperia 10 II and it doesn’t work either.
The cheat sheet seems to be outdated. You need to specify a correct collectionId to the command so it finds the correct database.
I managed to get an export done using:
$ pkcon install nemo-qml-plugin-contacts-qt5-tools
$ devel-su -p contacts-tool collections
# this will print something like:
#      ID: qtcontacts:org.nemomobile.contacts.sqlite::xxxxxxxx31  Name: aggregate
#      ID: qtcontacts:org.nemomobile.contacts.sqlite::xxxxxxxx32  Name: local
#      ID: qtcontacts:org.nemomobile.contacts.sqlite::xxxxxxxx33  Name: SIM
#      ID: qtcontacts:org.nemomobile.contacts.sqlite::xxxxxxxx34  Name: SIM
# now take one of the ids (full string) and export the contacts:
$ devel-su -p  vcardconverter --export contacts_aggregate.vcf  qtcontacts:org.nemomobile.contacts.sqlite::xxxxxxxx31
Or, putting it all together:
 contacts-tool collections | awk '{print "vcardconverter --export " $2 "_" $4".vcf, $2"} | sh'
Now that SFOS docs are a wiki, someone who cares may update the cheat sheet source…
Oh, you edited already.
Thank you for the alternative solution.
In two words, the cheat sheet command works for me if executed as specified. edit: for local contacts.
I added a comment to explicitly say it doesn’t work as root but only as user with devel-su -p
We made an error and didn’t RTFM correctly!
Sorry for the very bad signal/noise ratio of this thread.
I just tried on my side. I got an error and an empty file.
This is very strange…
As defaultuser in the stock shell?
I did export in /home/defaultuser/Documents
I got it. It’s because all of your contacts are stored locally. In my case, I save them on my Nextcloud server (with CardDAV).
Oh, I understand.
So I’ll edit my edit…
Thanks all for working this through. From what I understand, there’s no longer anything to address here: the solution is marked. So I’ve tagged this as “fixed”.
