Downloads for SW binaries mostly missing
Following the installation guide for the Xperia 10 IV, it seems like the AOSP software binaries are no longer available from Sonys website (it returns a 200, but with the message ‘Page Not found’).
I can also access none of the binary links for other devices from sonys mainlined devices page (I wanted to put a link, but I’m not allowed to)
I remember being able to download binaries about a year ago, but I have looked a few times in the past few months and had no luck. I live in germany, so geoblocking should not be an issue.
Does someone have these binaries and can provide a link to them?
Please check here:
If AppSupport is not a requirement, I reccomend using my Lineage port over the Jolla/SODP port. Much more functional as a daily driver.
Thanks @yusssufff , I found the binaries. It seems the address changed from developer.sony.com to opendevices.sony.net.
@Sharks Thank you very much for your work on the port! I was already planning to install it. I just wanted to install the official version first to grab the AAS packages and to get a clean copy of the fully installed filesystem just in case I need it. (I’m new to SFOS, so I don’t know what I might need in the future)
You are welcome. Can you tick the solution and rename your thread as solved?
I have been fighting in sony open devices repo in issues section for working blobs for a while - my requested blobs archive Android 13 Kernel 5.4 v4b was restored in access. Check yours again, maybe they are available too.
