If there are only some significant fixes it means that this issue will remain and switching between WiFi and Cellular will still not work as expected for Android apps.
I guess you work about the root partition space needed to perform an upgrade.
This is an arbitrary limit determined empirically. It is set to ensure free space remains abundant during the upgrade install. I think it is not linked directly to the size of the upgrade which is downloaded to the user partition anyway.
I have face the same issue with the recent update. Luckily I remembered I installed caligraconv just recently. Removing (whole) calligra and a couple of log files (upgrade log) got me back to have just a bit over 500MB of root free space. The upgrade completed without an issue.
Still I’m wondering what I have installed that consumes all the root partition space (btw. I’m on Xperia X).
Maybe one should increase the size of rootfs (at the cost of some /home space)? Are there any problems / disadvantages with doing so? How about 4 GB of rootfs? It wouldn’t hurt free space left on home partition too much.
Well, using the GUI I had repeatedly problems (i.e. failed updates that had to be repeated, boot-loops, etc.), whereas via CLI never. Just issue both commands and that’s it
It would indeed be nice if L10N files would be split out of the relevant packages. That would save (if unwanted languages are uninstalled) about 100MB on the root fs.
Yes. Another solution, perhaps, might be to port Debian’s localepurge script to SFOS. Localepurge has been ported to Arch Linux. It is in the user repository (git clone https://aur.archlinux.org/localepurge.git). I thought maybe this version would be a good starting point for a port to SFOS if anyone could be interested in undertaking this task?
With 4.3.0.15 on Xperia 10 still problems with Advanced Camera. Main camera + flash worked exactly one time after installing and never again. Selfie camera works fine.
Only a week ago I’ve had over 900 MB of free space on the rootfs. Now I have 750 MB and I wonder where did nearly 200 MB go. The only important thing that I did in the meantime was appying the 4.3.0.15 OS update. Did it eat 200 MB or what? Where should I look and what to check?
