REPRODUCIBILITY: 0% (not specified)
OSVERSION: 4.4.0.72
HARDWARE: Sony Xperia 10 III - xqbt52 - xqbt52 - 1.0.0.176 - aarch64
REGRESSION: no
The data counters for SIM1 don’t appear to work, all values show zero. The counters do work for WLAN.
- Use mobile internet for an hour or so
- Go to Settings > System > Data counters
- SIM1 shows 0 bytes for all fields
EXPECTED RESULTS:
I want to be able to estimate how much of my data bundle I used up.
ACTUAL RESULTS:
No way to tell because all values are stuck at zero.
- Patchmanager: no
- OpenRepos: yes
- Chum: yes
- Other: no:
I’ve been using the phone and mobile data for months now, so it appears it has never worked to begin with, while wlan counters have been working (it says received hundreds of gb).
Home Encryption: enabled
