The SRAM AXS app (Android) can be wireless connected to your bicycle components to configure them.
However, this requires a working bluetooth connection. In the past, bluetooth did not work for Alien Dalvik, but what about newer SFOS generations like Xperia 10 III?
No; you can just know that Bluetooth, NFC, WiFi-management and VPN Android apps simply will not work, as those things are part of the underlying OS. Delegating control over them to the Android runtime in a way that appears somewhat complete would be hard if not impossible.
This limitation has always been there, and i don’t see it changing substantially.
(Well, NFC should be toggle-able, but it probably is not prioritized)
