reducing risk up upgrade failures caused by third-party repos (OpenRepos), because:
of per-release repos and builds on OBS/chum
less breakage with compatability changes
less “aging” of unmaintained repos because of auto-rebuild
speeding up adoption of new architecture (see the whole “app not available on aarch64” topic)
low barrier to entry for new developers: while OBS and all that goes with it is not easy to learn, collaborative building development can be helpful to app developers compared to development and building locally using SDK
low barrier to entry for picking up and maintaining abandoned apps (because they are quick to get built, and through community repos such as the chum github community can achieve more reliable maintainership)
increased quality of .specs/dependencies because of differences in OBS and SDK build environments
It’s been now more than a week since I’ve been trying to get an account created at OBS. Is there any other way to achieve it, other than counting on @lbt’s response which doesn’t come?
Try using build.merproject.org instead of build.sailfishos.org, they both resolve to the same IP address.
Note that the DNS entry for build.sailfishos.org has been broken for long, but seems to be fixed recently.
Thanks, but that wasn’t the issue . When trying to login on build.merproject.org it gives “Authentication failed”, while I was able to login on bugs.merproject.org (it seems to be down now).
