Can't reflash Sony Xperia 10 IV
Hey,
I’ve forgotten my pin for a fresh jolla installation on Xperia 10 IV (played around some time ago - forgot it). So now I just want to start over at reinstall Sailfish.
But when I try to reflash using the instructions here: Reinstalling Sailfish OS | Sailfish OS Documentation
… the proces halts, with a: < waiting for HQ62681C99> during which the phone then boots into sailfishos, and waits for the pin code that I forgot. And then nothing happens.
The led was blue, but when it gets to the “waiting” message it turns red and boots, as described.
Any ideas on what I’m doing wrong?
Output here:
❯ sudo bash ./flash.sh
Flash utility v1.2
Detected Linux
Searching device to flash..
Found XQ-CC54, serial:HQ62681C99, baseband:65.2.A.2.270, bootloader:6375-0001_X_Boot_SM6375_LA2.0.1_T_116
Found matching device with serial HQ62681C99
Fastboot command: fastboot -s HQ62681C99
>> fastboot -s HQ62681C99 getvar secure
<< secure: no
>> fastboot -s HQ62681C99 reboot fastboot
Rebooting into fastboot                            OKAY [  0.005s]
Have you looked into this thread?
The problem, in this thread, was with Windows, but maybe it help you too.
Ok thanks. That thread is about windows (I’m on linux), and the solution is to update the android drivers in windows. The fastboot-install on my debian is the latest. So I don’t think it is the same thing.
Iinvestigated a bit more from the thread though:
Tried with –force from this thread: Xperia 10 IV flash 4.6.0.15 faulty - #6 by lhodas – did not work
Tried removing usb auto-suspend from this thread: [Linux] fastboot: error: Couldn't parse partition size '0x' - #14 by direc85 – did not work
Try it this way:
wup wup that worked.
Had an issue with flashing the vendor image: Sony Xperia 10 III, Android 13 - how can I flash SailfishOS to this device? - #13 by jwalesch
But when i disconnected and booted it worked as a fresh install- I guess the vendor image was already flashed back when flashing the first time.
Thanks so muuuuch! Love this forum!
