So, I’ve been using Sailfish since the start with J1. It’s been increasingly tricky to get the MMS working. I have had to tinker a lot with different settings, using alternative IP proxy addresses and access point names. In the end, after a lot of effort, I’ve managed to get it working.
This time not so. I’ve been trying all kind of settings to no avail and searched the forum and tried all suggestions but no cigar. It is extremely frustrating and I can’t think of more to do. I’m using a ver 4.4.0.68 on Xperia 10 iii .
Symptoms right now are that when receiving an mms, it says downloading but nothing comes and in the end a message that the mms failed to download.
Sending an mms fails and in the logs I find:
12:25:53 [mms-connection-nemo] MessageCenter: http://mms.tre.se
12:25:53 [mms-connection-nemo] Activate /ril_0/context2
12:25:53 [mms-ofono] Activating /ril_0/context2
12:25:53 [mms-ofono] ERROR: GDBus.Error:org.ofono.Error.Failed: Operation failed
12:25:53 [mms-ofono] Giving up on /ril_0/context2
12:25:53 [mms-dispatcher] 240020011209428 FAILED
Any help with this would be much appreciated.
Or if anyone using Swedish 3 having it work and the right settings I would appreciate knowing those.
Pete
