After upgrading to 4.5.0.19 I cannot make phone calls or receive calls.
REPRODUCIBILITY: systematic
OS VERSION: 4.5.0.1
HARDWARE: xperia 10 II-dual xqau52
UI LANGUAGE: French
REGRESSION: yes - worked on previous OS
ISP : freemobile
Phone calls cannot be made
callers get a busy tone even I am not on the phone
To reproduce, either
use contacts
select a contact
press phone number
or
open phone app
select a number
press the number
or
open phone app
select keyboard
type a number
press call
What happens : Nothing
Expected : the call is made
reciprocally:
someone calls me
What happens:
he gets a busy tone
Expected :
they get a ring
if I pick up , we have a phone call
use openrepos
use chum (amazfit + some games)
using in development crypto sdcard in cooperation with Olf
I noted that
voicecall-manager.service is failed, using SailorD
the service calls /usr/bin/invoker -o --type=qt5 /usr/bin/voicecall-manager
If I do it directly, I have
[root@Xperia10II-DualSIM defaultuser]# /usr/bin/invoker -o --type=qt5 /usr/bin/voicecall-manager
invoker: error: XDG_RUNTIME_DIR is not defined.
invoker: warning: Also fallback boosters failed, launch without boosting.
invoker: warning: Connection with launcher process is broken.
invoker: error: Start application /usr/bin/voicecall-manager as a binary executable without launcher…
Illegal instruction (core dumped)
Calling /usr/bin/voiceall-manager results also in Illegal instruction
similarly, the vibration on screen touch is not working either
I can confirm this issue, this already exists since 4.5.0.16. I upgraded using the standard procedure via settings.
I did not find the time to post a bug report or provide some reproduction steps, I will try to do so later after I am able to verify those.
Some further details on my experience:
What does not recover the device from this issue:
Toggling airplane mode
Restarting network services via settings utilities
Toggling network settings
What does recover the device from the issue:
Reboot
systemctl restart ofono command
Bug specifics:
Any phone functionality is broken (this is actually a very critical issue, due to broken emergency calls!)
The Phone app cover displays an ongoing call even though no call is active
After executing systemctl restart ofono command the “Phone call ended/terminated” dialog is displayed even though there was no active phone call
Hi,
can we create a bug report against poor testing?
I am complaining since a long time that things are getting worse with each release.
When will Jolla start testing better before releasing?
Why is there the EA and what is it good for when so many critical bugs are being reported after release?
I’m surely not touching the phone when reading so many bug reports after 4.5.0.16
This is serious! I once wrote that some of the former Nokia employees know very well how they did Harmattan 1.2.
I can swallow some minor bugs, but this one … confirmed by multiple users …
please post at least what is the expected release date for the fix.
We have received some logs from @ddelamarre (thank you). It is not yet clear why phone calls have stopped working on his and on a few other users’ phones while they keep working fine on the phones of the vast majority.
We did not observe this problem on any of the phones on which 4.5.0.19 was tested prior to the rollout.
It is impossible to estimate a release date when the culprit of the reported issue is not clear.
I can understand that it is not possible to cover all variations. Forgive me my harsh remarks, but from my user perspective it is just making me nervous when reading these reports.
Especially after having experienced similar problems in the past.
I wish there were LTS version that I could stay on for a longer period of time, or an easy way to downgrade or rollback. For example at the moment with 4.4.0.72 I do not need to upgrade except for security reasons.
I do not recall if LTS was discussed or available.
I understand the complexity, but I think may be a wider circle of beta testers should be used before release.
This should be run as user and as root it’s not expected to work. But as root you could try “systemctl --user restart voicecall-manager” and check what gets printed on the journal.
I install Sailfish on my new Xperia … And no way to call or receive a call. I found this ticket and it is EXACTLY the same problem BUT I have one more information …
This happen ONLY with my Free sim card. I have another sim ( Bouygues for professional matters) and it works correctly !!! I made a log collect. Do you want me to furnish to you ? It depend on the operator use … Strange
Thanks to find a solution … It is a real pb a phone … which can make a phone call !
Well, neither your nor the original reporter mentions whether this is with VoLTE or not.
Some operators have been know to mess up legacy calling (or specifically the falling back from 4G to something that can support classic CS calls) for VoLTE-capable phones. Does it work if you manually select 2G or 3G?
Of course, for us … It is clearly a black box And I am not able to speak about VoLTE as I don’t know aynything of this technology.
What I can tell you, I use an Xperia 10 plus … With 2G only, It works !!!
I will be a workaround until the correction … When I select “prefers 3G” … I have no network !! I tried twice, back to 4G and back to 3G … No able to catch network with 3G… Now, Free operator was not very old and as far I am remembered, they built only 4G antenna … Maybe, there is no 3G antenna around. I will try tommorow somewhere else …
If you need any other data … I would be please to anwser to your question Regards
I said my SIM2 is working … BUT … I discover this morning after many tries that Sim2 is not working anymore because … it was my data sim selected !!! There is clearly a link with data mobile. The sim selected for data mobile need to be in 2G to be able to make a call … The other does not have any problem to work. Hope it helps …
