i would to restore my backup from my old device XA2 Plus to the C2 using dropbox.
I tried this by first creating a backup on my C2 to get the directory on dropbox. Then i moved
my XA2 Backup to the C2 backup directory and tried to restore it. The result was:
restoring accounts failed accounts are there, but all password are missing, so the accounts are not yet usable.
Calendar contained some entries (not check if all), but looks ok on first sight.
SMS Messages look ok.
Browser Bookmarks also look ok
Restoration failed with error: “Error: cannot load Notes”
Contacts, Notes and all the custom stuff via MyBackup is missing.
How can i check why notes restoration failed? How to fix that (do i have to modify the backup zip somehow?) Removing notes - so the restoration process continues?
Is this perhaps the classic nemo/defaultuser having leaked into the backup?
Then you can temporarily symlink one to the other.
Search for more info - other threads exist.
