My C2 phone is permanently locked. It says that there were too many attempts.
I rebooted many times. The code on the black screen works well but for the screen to open, it says what I wrote above. What can I do?
Hi filip.k,
Nothing important on the phone itself, everything on the sdxc.
Never flashed the C2. Any detailed instructions on how to do it on an arch-based distro?
[quote=âgaleva, post:1, topic:24552â]
I was successfully flashed my C2 phone. The process is easy and everything went as it was described. I used an arch-based distro for this process. If you are on Arch or and Arch-based distro and do not have âfastbootâ, which is part of the âAndroid Platform Toolsâ known as âandroid-toolsâ, just install the âandroid-toolsâ in Terminal with this command:
sudo pacman -S android-tools
The entire flashing process will run smoothly then.
Thank you again to jovirkku for a good description.
