C2 factory reset issue
Hi all. I bought the new phone, so now I want to give away my C2 to a friend, but I’m unable to factory reset it.
I’m able to start the procedure from settings, but when the phone reboots, I get this error message:
“Factory image not found or invalid.
Rebooting back to current system.“
Anyone else had this issue and know how to fix it or get around it? Maybe I can replace the factory image on the device?
I found a guide for recovery mode on Zendesk, but there’s no article for the C2. Can I follow the guide for one of the other devices? https://jolla.zendesk.com/hc/en-us/articles/204709607-Jolla-Phone-How-to-use-Recovery-Mode
I had sama problem with my previous Jolla C2. And I askel help from Jolla Zendesk.
Here is Jolla’s answer:
Hello,
You are right in that there is no reset on the C2. However, you can reset everything by reinstalling the Sailfish OS.
The instructions are here: https://forum.sailfishos.org/t/fastboot-flashing-of-jolla-c2/21482
Ystävällisin terveisin,
Jolla Mobile Asiakastuki
Worked like a charm. Thanks!
Wait, I just thought of something. Since this is a “free trial” licence, does that mean my friend won’t be able to run Android apps on the phone?
afaik there is only one image to use. When you pay a license, you can then download Android App Support plus some additional packages.
Android Application Support ( Android version 13, API level 33)
is available for C2 in Store for free like for mine after reflashing.
You need to be logged with Jolla account to access Store.
I just don’t know how to transfer your C2 device purchace in Jolla
Shop to your friend’s Jolla account.
I think that AAS licence has been paid and attached to device.
rgds nasta
