Bugs in Patchmanager ≥ 3.1.0
Supposed to be fixed in 3.2.8, see:
Encountered a strange bug/issue:
tried to search Web Catalog, which couldnt connect or had some other issue, just saw the spinner on blank page, after a short time (~60 sec ?), spinner froze, display went black and wouldnt recover until (systemd was also “dead”, systemctl or journalctl commands didnt respond at all):
[defaultuser@Fairphone4 Project]$ ps auxww|grep patch
 1312 root     /usr/sbin/patchmanager --daemon
11734 root     {rich-core-dumpe} /bin/bash /usr/sbin/rich-core-dumper --pid=1312 --signal=6 --name=patchmanager
12110 defaultu grep patch
[defaultuser@Fairphone4 Project]$ devel-su kill -9 11734 1312
afterwards display immediately turned on and everything is working as expected
I’m not familiar with rich-core-dumper - how does it get activated? Is it a hint that something segfaulted?
I dont know, i only have partial dmesg output, but cant see anything strange (but not sure), (edit: was useless)
so:
rich-core-dumper is basically just a huge shell script, which gets executed by helper binary (setuid binary probably only there to allow the shell running as root)
one symlink is broken, but if thats the issue not sure, service unit seems working fine
/run/systemd/units/invocation:rich-core-early-collect.service: broken symbolic link to 158bce77036d49ba94db5b8ca357e12b
/usr/lib/systemd/system/graphical.target.wants/rich-core-early-collect.service: symbolic link to ../rich-core-early-collect.service
/usr/lib/systemd/system/rich-core-early-collect.service: ASCII text
/usr/lib/startup/preinit/late.d/rich-core-preinit: POSIX shell script, ASCII text executable
/usr/lib/sysctl.d/sp-rich-core.conf: ASCII text
/usr/libexec/rich-core-helper: setuid ELF 64-bit LSB executable, ARM aarch64, version 1 (SYSV), dynamically linked, interpreter /lib/ld-linux-aarch64.so.1, BuildID[sha1]=3d55833a001b9bde3352a1549d94effe38524a7d, for GNU/Linux 3.7.0, stripped
/usr/libexec/rich-core-check-oneshot: POSIX shell script, ASCII text executable
/usr/share/licenses/sp-rich-core-1.75.0: directory
/usr/sbin/rich-core-dumper: Bourne-Again shell script, ASCII text executable
[defaultuser@Fairphone4 ~]$ systemctl --no-pager status rich-core-early-collect.service
● rich-core-early-collect.service - Collects system logs early after boot if error conditions are detected.
   Loaded: loaded (/usr/lib/systemd/system/rich-core-early-collect.service; disabled; vendor preset: enabled)
   Active: active (exited) since Mon 2025-11-24 23:28:21 CET; 10h ago
  Process: 5488 ExecStart=/bin/touch /tmp/richcore-early-collect-mark (code=exited, status=0/SUCCESS)
  Process: 5484 ExecStart=/bin/sh -c    grep "Shutdown:" /var/log/systemboot.log | tail -n1 | grep -qi "overheat" &&    /usr/sbin/rich-core-dumper --name=OverheatShutdown --signal=$RANDOM (code=exited, status=1/FAILURE)
  Process: 5471 ExecStart=/usr/libexec/rich-core-check-oneshot (code=exited, status=0/SUCCESS)
  Process: 5467 ExecStart=/bin/sh -c    STATUS=$(/bin/sed -n "s|.*reset=kernel_wdt\([^ ]*\).*|HWreboot|p" /proc/cmdline) &&     /usr/bin/test -n "$STATUS" &&   /usr/sbin/rich-core-dumper --name=$STATUS --signal=$RANDOM (code=exited, status=1/FAILURE)
  Process: 5464 ExecStart=/bin/sh -c    STATUS=$(/bin/sed -n "s|.*pwr_on_status=pwr_on_by_HW_\([^ ]*\).*|HW\1|p" /proc/cmdline) &&      /usr/bin/test -n "$STATUS" &&  /usr/sbin/rich-core-dumper --name=$STATUS --signal=$RANDOM (code=exited, status=1/FAILURE)
  Process: 5371 ExecStartPre=/usr/lib/startup/wait-for-file /run/user-session/post-user-init-done.flag (code=exited, status=0/SUCCESS)
 Main PID: 5488 (code=exited, status=0/SUCCESS)
after checking the conf file:
privacy-notice-accepted=false
it should abort early? according to this:
# If the user hasn't agreed to the privacy notice abort here.
if [ x"${privacy_notice_accepted}" = x"false" ]; then
  _log_msg "rich-core: privacy notice not accepted - not dumping"
  exit
fi
But maybe then this is causing some issues? (if the setuid helper starts the script it runs as pid 0 ?)
# If dumping is disabled in settings, don't bother going further. However, the
# setting is overriden if this dump was invoked with PID 0, meaning only logs
# are collected, or the process was killed by SIGQUIT, which means user
# explicitly requested its termination from quick-feedback application.
if [ x"${coredumping}" = x"false" ] && { [ ! $core_pid -eq 0 ] || [ $core_sig -eq 3 ]; }; then
  cat > /dev/null
  exit
fi
Thanks for the research. It’s a bit hard to triage this after the fact.
Now, while it’s quite possible that the PM crashed, and also possible for them to take Lipstick down (–> black screen), this really shouldn’t make the system unresponsive or even systemd not react any more.
What I believe may be the case here is that the rich core dumper collection resulted in a heavy IO, possibly OOM situation.
If that rich-core dumping tool
a) does not set the NO_PM_PRELOAD=1 variable (which disables the patchmanager preload) - and there’s no reason to believe it does
b) does not allow the patchmanager daemon to restart or otherwise act until it’s finished it collecting
this could cause lots of tries by the preload library to contact the daemon (it’s asking whether there are any patched files accessed), which may fail or deadlock.
Not sure what exactly happens in the kernel in such a situation, but I guess things like an overly long wait queue, very high loadavg while no or little CPU is being used and so on.
Which could explain what you are describing, black screen, some services not responding, but otherwise responsive system.
All this is a pure theory however.
In case you ever see this again, could you gather some info about:
  • memory usage
  • load averages
  • queues
  • top CPU and I/O processes?
basically what the dstat --load --cpu --page --disk --top-cpu --top-io --top-mem' tool shows.
if i encounter this bug again and have ssh connection i’ll try to get more infos, should have at least checked top to see cpu and mem usage, but I always forget that busybox ps is very minimal and ps auxww is useless there (else it would show at least cpu and mem usage)
bug is currently occuring again, unfortunately I cant connect to phone
ssh just hangs, display wont turn on
$ ssh defaultuser@192.168.2.106
ssh: connect to host 192.168.2.106 port 22: Connection timed out
if you encounter this and arent already connected via ssh, no way to gain access to the device
kex_exchange_identification: read: Software caused connection abort
banner exchange: Connection to 192.168.2.106 port 22: Software caused connection abort
edit:
also openrepos certificate expired again, maybe its related (this time)?
Problem retrieving files from 'openrepos-flypig'.
Download (curl) error for 'https://sailfish.openrepos.net/flypig/personal/main/repodata/repomd.xml':
Error code: Curl error 60
Error message: SSL certificate problem: certificate has expired
triggered again:
screen wont turn on:
top normal:
[defaultuser@Fairphone4 mednafen]$ top -bn 1|head -n 50
Mem: 4507344K used, 1128056K free, 319984K shrd, 179064K buff, 1790384K cached
CPU:  1.1% usr  1.1% sys  0.0% nic 97.7% idle  0.0% io  0.0% irq  0.0% sirq
Load average: 0.39 3.90 3.48 2/1699 9027
  PID  PPID USER     STAT   VSZ %VSZ CPU %CPU COMMAND
 2149  1232 system   S    10.5g197.1   0  0.7 {sensors@2.0-ser} /vendor/bin/hw/android.hardware.sensors@2.0-service.multihal
 9026 41139 defaultu R     3580  0.0   7  0.7 top -bn 1
  508     2 root     SW       0  0.0   2  0.7 [crtc_event:110]
 2468  1232 radio    S    11.9g221.9   4  0.0 {main} /vendor/bin/hw/qcrild
 2578  1232 radio    S    11.7g218.7   7  0.0 {main} /vendor/bin/hw/qcrild -c 2
 9947  1232 camerase S    11.4g212.2   5  0.0 {provider@2.4-se} /vendor/bin/hw/android.hardware.camera.provider@2.4-service_64
 2400  1232 root     S<   11.4g212.0   2  0.0 /vendor/bin/thermal-engine
 2136  1232 system   S    11.3g211.1   7  0.0 /vendor/bin/ssgtzd
 2402  1232 radio    S    11.2g208.3   2  0.0 /system/vendor/bin/netmgrd
 2365  1232 media    S    10.9g203.9   0  0.0 /usr/libexec/droid-hybris/system/bin/minimediaservice
 2144  1232 gps      S    10.9g203.1   0  0.0 {gnss@2.1-servic} /vendor/bin/hw/android.hardware.gnss@2.1-service-qti
 2413  1232 mediacod S    10.9g203.0   2  0.0 {binder:2413_2} media.swcodec oid.media.swcodec/bin/mediaswcodec
 7975  1232 system   S    10.7g199.2   6  0.0 {composer-servic} /vendor/bin/hw/vendor.qti.hardware.display.composer-service
 3878  1232 radio    S    10.6g198.0   6  0.0 /vendor/bin/ims_rtp_daemon
 2964  1232 radio    S    10.6g197.7   0  0.0 /vendor/bin/imsdatadaemon
 2389  1232 system   S    10.6g197.5   2  0.0 /system/vendor/bin/cnd
 2213  1232 root     S    10.5g196.7   3  0.0 {perf@2.2-servic} /vendor/bin/hw/vendor.qti.hardware.perf@2.2-service
 2146  1232 system   S    10.5g196.2   1  0.0 {neuralnetworks@} /vendor/bin/hw/android.hardware.neuralnetworks@1.3-service-qti
 3024  1232 system   S    10.5g195.6   4  0.0 /vendor/bin/hvdcp_opti
 2366  1232 system   S    10.5g195.3   7  0.0 /usr/libexec/droid-hybris/system/bin/minisfservice
 1300  1232 system   S    10.5g195.3   6  0.0 {suspend-service} /system/bin/hw/android.system.suspend-service
 1278  1232 system   S    10.4g194.8   3  0.0 /vendor/bin/qseecomd
 3888  1232 radio    S    10.4g194.8   6  0.0 /vendor/bin/imsrcsd
 1301  1232 keystore S    10.4g194.8   6  0.0 {binder:1301_2} /system/bin/keystore2 /data/misc/keystore
 2232  1232 credstor S    10.4g194.8   6  0.0 /system/bin/credstore /data/misc/credstore
 1782  1232 radio    S    10.4g194.8   6  0.0 /system/vendor/bin/ipacm
 2643  2420 gps      S    10.4g194.5   7  0.0 lowi-server
 2875  1232 system   S    10.4g194.3   2  0.0 /system/vendor/bin/dpmQmiMgr
 2660  1232 radio    S    10.4g194.2   3  0.0 /system/vendor/bin/adpl
[defaultuser@Fairphone4 mednafen]$ dool --help
^C
[defaultuser@Fairphone4 mednafen]$ dstat --load --cpu --page --disk --top-cpu --top-io --top-mem'
> ^C
^C
dstat or other commands did not work
[defaultuser@Fairphone4 mednafen]$ pgrep rich
8722
[defaultuser@Fairphone4 mednafen]$ kill -9 8722
bash: can't kill pid 8722: Operation not permitted
[defaultuser@Fairphone4 mednafen]$ devel-su kill -9 8722
kill rich-core.dumper, everything works again
┄┄┄load┄avg┄┄┄┬┄┄total┄cpu┄usage┄┄┬┄┄┄paging┄┄┬┄dsk/total┄┬┄most┄expensive┄┬┄┄┄┄┄┄┄┄top-io┄┄┄┄┄┄┄┄┬┄┄most┄expensive┄
 1m   5m  15m │usr sys idl wai stl│  in   out │ read  writ│  cpu process   │    name    read  writ│  memory process
0.18 1.70 2.65│  5   8  87   0   0│4534B   14k│1322k  220k│lipstick     0.3│systemd      29k 2337B│lipstick     263M
Hi, thanks for reporting again and trying to debug!
It is clear that something is deeply wrong with the system when this occurs.
I am not convinced yet that Patchmanager has anything to do with it - although technically it is entirely possible that it does, or has some interaction with this rich-core-dumper tool that causes the issue.
But what we need here is a reproducer. We need to find a reliable, repeatable way to trigger this issue. I don’t see how it can be debugged otherwise.
yes maybe a issue in the script (or the service which starts the script), I dont know, maybe next time it happens (if it happens again) I’m able to get some more info
I checked if there is some (rich-core) log created but unfortunately not
[defaultuser@Fairphone4 ~]$ ls -l /var/cache/core-dumps/|grep "Dec 23"
-rw-r--r--    1 root     root        434970 Dec 23 11:53 a.out-fp4-11-22412.rcore.lzo
-rw-r--r--    1 root     root        397521 Dec 23 10:31 android.hardware.audio.service-fp4-11-2137.rcore.lzo
-rw-r--r--    1 root     root        432767 Dec 23 10:32 android.hardware.camera.provider@2.4-service_64-fp4-6-2140.rcore.lzo
-rw-r--r--    1 root     root        420665 Dec 23 14:00 exec_cmd-fp4-11-13514.rcore.lzo
-rw-r--r--    1 root     root        430497 Dec 23 12:04 exec_cmd-fp4-11-38153.rcore.lzo
-rw-r--r--    1 root     root        407356 Dec 23 16:41 exec_cmd-fp4-11-4752.rcore.lzo
-rw-r--r--    1 root     root        404474 Dec 23 16:03 x64-fp4-11-47790.rcore.lzo
-rw-r--r--    1 root     root        401193 Dec 23 16:09 x64-fp4-11-48374.rcore.lzo
-rw-r--r--    1 defaultu defaultu   2213694 Dec 23 16:09 x64-fp4-11-48772.rcore
-rw-r--r--    1 root     root        395906 Dec 23 16:09 x64-fp4-11-48772.rcore.lzo
-rw-r--r--    1 root     root        395545 Dec 23 16:14 x64-fp4-11-49224.rcore.lzo
-rw-r--r--    1 root     root        383822 Dec 23 16:18 x64-fp4-11-50001.rcore.lzo
