REPRODUCIBILITY (% or how often): 50%
BUILD ID = OS VERSION (Settings > About product): 4.4.0.58
HARDWARE (XA2, X10, X10 II, …): XA2+
UI LANGUAGE: ru
REGRESSION: (compared to previous public release: Yes, No, ?): no
When start some multimedia android app, its work fine with bluetooth control (pause,play, next, previous). After few reconnections, its just stop control any multimedia in android and some native app s to ( in native stock mediaplayer it works fine always )
just enable/disable bluetooth, connect/reconnect or somthing
cant reproduce with some fixed steps
should always work as expect
randomely just stops work
Sometimes just restarting aliendalvik helps, sometimes not help
Maybe someone can tell what subsystem i should restart to activate bluetooth multimedia controls work again with android apps
In same time, multimedia control butoons on lock screen works normal
