Browser - Cookie whitelist not working
BUILD ID = OS VERSION (Settings > About product): 4.4.0.58
HARDWARE (XA2, X10, X10 II, …): X10 Plus
UI LANGUAGE: Finnish
Cookies not working on whitelisted sites when cookies are disabled in browser settings
Update from 4.3 to 4.4.0.58
  1. Disable cookies in browser settings
  2. Whitelist site in cookie exceptions
  3. Visit site and do something that requires cookies
Cookies are working
Cookies are not working on
Cookie whitelist worked on Sailfish 4.3
CONSOLE message:
[JavaScript Warning: "Request to access cookie or storage on “https://forum.sailfishos.or
g/” was blocked because we are blocking all storage access requests."]
Thank you for your bug report. I need some more clarification. When do you mean Disable cookies, does it mean you set the option Block Cookies under Permissions?
I’m unable to reproduce your bug. There is surely a missing step. Since you use Sailfish, have you always blocked cookies?
EDIT: Clearing all browser data has made some mess. Good to know. I’m able to reproduce now.
Step 0) Clear all browser data
Thanks for the bug report @jokujossai, and thanks @pherjung for flagging it up, as well as for the testing and improvements to the description. This is all really helpful.
I’ve created an internal bug report about this and marked it as tracked.
Retested: disabled cookies globally and tried loading forum.sailfishos.org → stuck in the dot animation. Enabled cookies for the site and reloaded → loads ok.
Not sure about the exact cookie requirements there, but I’m guessing this might have been fixed these days.
