Browser: Bookmarks does not show, typing hides keyboard
REPRODUCIBILITY: 10-30%
OS VERSION: 4.4.0.72
HARDWARE: Xperia 10 III
UI LANGUAGE: Swedish
REGRESSION: Yes (but probably a few versions ago)
Continued from here: Browser address bar input loses focus after first character in Landscape mode - #13 by thigg
Sometimes when i press the address bar in the browser, the bookmarks grid comes up empty/black.
If i then type a letter, it pops in, but while doing so the keyboard is closed.
None.
  1. With a web page open, press the address bar.
Bookmarks displayed, keyboard not getting hidden.
No bookmarks displayed, keyboard hidden when i start typing.
None.
It appears more common in landscape mode.
Can you take a look at the logs, when the bookmarks do not show up? Do you have a high number of bookmarks? Does this only happen in landscape or also in portrait orientation?
Unfortunatley could not observe that behavior yet on my 10II with 4.4.0.72
I’ll try. Of course it doesn’t happen when i try to reproduce it. And generally i mostly use the phone when i’m not also at the computer, so collecting logs is not so easy.
I have about 100 bookmarks.
I’m not 100% sure if it is limited to landscape, but i don’t think it is.
Make your logs persistent: Sailfish OS Cheat Sheet | Sailfish OS Documentation
Then you can take a look when you’re back home.
Or just do a devel-su journalctl > issue-xyz.log
added it to the debug wiki post
Kind of sketchy to find the relevant section again, but fortunately screenshots show in the log.
Nothing looks particularly interesting/related.
log
nov 20 22:36:00 Xperia10III kernel: pm7250b_charger: chg_state_change_irq_handler: IRQ: chg-state-change
nov 20 22:36:00 Xperia10III kernel: QG-K: get_batt_id_ohm: batt_id_mv=245, batt_id_ohm=15000
nov 20 22:36:00 Xperia10III healthd: battery l=83 v=4241 t=30.5 h=2 st=2 c=0 fc=4529000 cc=67 chg=a
nov 20 22:36:00 Xperia10III kernel: ALG: cap_learning_update: [SOMC CL][OFF] charge_status:1 bsoc_cp:8253
nov 20 22:36:00 Xperia10III kernel: pm7250b_charger: somc_aicl_irq_handler: IRQ: input-current-limiting
nov 20 22:36:00 Xperia10III mce[1996]: modules/battery-udev.c: udevdevice_lookup_charger_type(): unknown charger type: USB_PD
nov 20 22:36:00 Xperia10III mce[1996]: modules/battery-udev.c: mcebat_update(): battery_state: not_charging -> charging
nov 20 22:36:00 Xperia10III kernel: binder: 7326 RLIMIT_NICE not set
nov 20 22:36:00 Xperia10III kernel: pm7250b_charger: somc_aicl_irq_handler: IRQ: aicl-done
nov 20 22:36:00 Xperia10III kernel: pm7250b_charger: default_irq_handler: IRQ: usbin-collapse
nov 20 22:36:00 Xperia10III kernel: pm7250b_charger: usbin_uv_irq_handler: IRQ: usbin-uv
nov 20 22:36:00 Xperia10III kernel: pm7250b_charger: default_irq_handler: IRQ: usbin-vashdn
nov 20 22:36:00 Xperia10III kernel: pm7250b_charger: smblib_usb_plugin_locked: IRQ: usbin-plugin detached
nov 20 22:36:00 Xperia10III kernel: pm7250b_charger: typec_state_change_irq_handler: typec_state_change_irq_handler in gpio84 set 0
nov 20 22:36:00 Xperia10III kernel: pm7250b_charger: typec_state_change_irq_handler: IRQ: cc-state-change; Type-C SOURCE_DEFAULT detected
nov 20 22:36:00 Xperia10III kernel: QG-K: get_batt_id_ohm: batt_id_mv=241, batt_id_ohm=15000
nov 20 22:36:00 Xperia10III healthd: battery l=83 v=4241 t=30.6 h=2 st=3 c=377502 fc=4529000 cc=67 chg=
nov 20 22:36:00 Xperia10III kernel: pm7250b_charger: typec_attach_detach_irq_handler: IRQ: typec-attach-detach
nov 20 22:36:00 Xperia10III kernel: pm7250b_charger: typec_state_change_irq_handler: IRQ: cc-state-change; Type-C NONE detected
nov 20 22:36:00 Xperia10III kernel: pm7250b_charger: typec_state_change_irq_handler: typec_mode:0,Type-C NONE detected gpio84 set 1
nov 20 22:36:00 Xperia10III kernel: usbpd usbpd0: USB Type-C disconnect
nov 20 22:36:00 Xperia10III mce[1996]: modules/battery-udev.c: mcebat_update(): charger_type: other -> none
nov 20 22:36:00 Xperia10III mce[1996]: modules/battery-udev.c: mcebat_update(): charger_state: on -> off
nov 20 22:36:00 Xperia10III mce[1996]: modules/battery-udev.c: mcebat_update(): battery_state: charging -> discharging
nov 20 22:36:00 Xperia10III healthd: battery l=83 v=4205 t=30.6 h=2 st=3 c=-408935 fc=4529000 cc=67 chg=
nov 20 22:36:01 Xperia10III kernel: pm7250b_charger: typec_state_change_irq_handler: typec_state_change_irq_handler in gpio84 set 0
nov 20 22:36:01 Xperia10III kernel: pm7250b_charger: typec_attach_detach_irq_handler: IRQ: typec-attach-detach
nov 20 22:36:01 Xperia10III kernel: pm7250b_charger: typec_state_change_irq_handler: IRQ: cc-state-change; Type-C SOURCE_HIGH detected
nov 20 22:36:01 Xperia10III kernel: usbpd usbpd0: Type-C Source (high - 3.0A) connected
nov 20 22:36:01 Xperia10III kernel: QG-K: get_batt_id_ohm: batt_id_mv=240, batt_id_ohm=15000
nov 20 22:36:01 Xperia10III healthd: battery l=83 v=4208 t=30.6 h=2 st=3 c=-369873 fc=4529000 cc=67 chg=
nov 20 22:36:01 Xperia10III kernel: QG-K: get_batt_id_ohm: batt_id_mv=241, batt_id_ohm=15000
nov 20 22:36:01 Xperia10III kernel: pm7250b_charger: usbin_uv_irq_handler: IRQ: usbin-uv
nov 20 22:36:01 Xperia10III kernel: pm7250b_charger: smblib_usb_plugin_locked: IRQ: usbin-plugin attached
nov 20 22:36:01 Xperia10III kernel: pm7250b_charger: default_irq_handler: IRQ: usbin-vashdn
nov 20 22:36:01 Xperia10III kernel: QG-K: get_batt_id_ohm: batt_id_mv=242, batt_id_ohm=15000
nov 20 22:36:01 Xperia10III healthd: battery l=83 v=4208 t=30.6 h=2 st=4 c=-369873 fc=4529000 cc=67 chg=
nov 20 22:36:01 Xperia10III usb_moded[3131]: unknown connection type reported, assuming disconnected
nov 20 22:36:01 Xperia10III mce[1996]: modules/battery-udev.c: mcebat_update(): charger_state: off -> on
nov 20 22:36:01 Xperia10III kernel: pm7250b_charger: smblib_set_icl_current: set ICL to 100000uA
nov 20 22:36:01 Xperia10III kernel: pm7250b_charger: somc_aicl_irq_handler: IRQ: aicl-done
nov 20 22:36:01 Xperia10III kernel: pm7250b_charger: smblib_set_icl_current: set ICL to 3000000uA
nov 20 22:36:01 Xperia10III kernel: QG-K: get_batt_id_ohm: batt_id_mv=244, batt_id_ohm=15000
nov 20 22:36:01 Xperia10III healthd: battery l=83 v=4209 t=30.5 h=2 st=4 c=-353698 fc=4529000 cc=67 chg=a
nov 20 22:36:01 Xperia10III usb_moded[3131]: unhandled power supply type: USB_PD
nov 20 22:36:01 Xperia10III mce[1996]: modules/battery-udev.c: udevdevice_lookup_charger_type(): unknown charger type: USB_PD
nov 20 22:36:01 Xperia10III mce[1996]: modules/battery-udev.c: mcebat_update(): charger_type: none -> other
nov 20 22:36:01 Xperia10III mce[1996]: tklock.c: tklock_dbus_notification_beg_cb(): notification begin from name=:1.69 owner=:1.69 pid=5752 uid=100000 gid=996 priv=1 cmd=/usr/bin/lipstick -plugin evdevtouch -plugin evdevmouse -plugin
nov 20 22:36:01 Xperia10III kernel: [schedu][0xaed4e5526c4][22:36:01.587295] wlan: [22257:I:OSIF] scan start scan id 41356
nov 20 22:36:01 Xperia10III kernel: binder: 7362 RLIMIT_NICE not set
nov 20 22:36:01 Xperia10III kernel: binder: 7143 RLIMIT_NICE not set
nov 20 22:36:01 Xperia10III kernel: pm7250b_charger: smblib_icl_change_work: icl_settled=500000
nov 20 22:36:01 Xperia10III healthd: battery l=83 v=4238 t=30.5 h=2 st=4 c=-17395 fc=4529000 cc=67 chg=a
nov 20 22:36:01 Xperia10III kernel: binder: 7364 RLIMIT_NICE not set
nov 20 22:36:01 Xperia10III kernel: binder: 7367 RLIMIT_NICE not set
nov 20 22:36:02 Xperia10III kernel: pm7250b_charger: chg_state_change_irq_handler: IRQ: chg-state-change
nov 20 22:36:02 Xperia10III kernel: QG-K: get_batt_id_ohm: batt_id_mv=244, batt_id_ohm=15000
nov 20 22:36:02 Xperia10III healthd: battery l=83 v=4239 t=30.5 h=2 st=2 c=0 fc=4529000 cc=67 chg=a
nov 20 22:36:02 Xperia10III kernel: ALG: cap_learning_update: [SOMC CL][OFF] charge_status:1 bsoc_cp:8253
nov 20 22:36:02 Xperia10III kernel: pm7250b_charger: somc_aicl_irq_handler: IRQ: input-current-limiting
nov 20 22:36:02 Xperia10III mce[1996]: modules/battery-udev.c: udevdevice_lookup_charger_type(): unknown charger type: USB_PD
nov 20 22:36:02 Xperia10III mce[1996]: modules/battery-udev.c: mcebat_update(): battery_state: discharging -> charging
nov 20 22:36:02 Xperia10III kernel: pm7250b_charger: somc_aicl_irq_handler: IRQ: aicl-done
nov 20 22:36:02 Xperia10III kernel: pm7250b_charger: usbin_uv_irq_handler: IRQ: usbin-uv
nov 20 22:36:02 Xperia10III kernel: pm7250b_charger: default_irq_handler: IRQ: usbin-collapse
nov 20 22:36:02 Xperia10III kernel: pm7250b_charger: default_irq_handler: IRQ: usbin-vashdn
nov 20 22:36:02 Xperia10III kernel: pm7250b_charger: smblib_usb_plugin_locked: IRQ: usbin-plugin detached
nov 20 22:36:02 Xperia10III kernel: pm7250b_charger: typec_state_change_irq_handler: typec_state_change_irq_handler in gpio84 set 0
nov 20 22:36:02 Xperia10III kernel: pm7250b_charger: typec_state_change_irq_handler: IRQ: cc-state-change; Type-C SOURCE_DEFAULT detected
nov 20 22:36:02 Xperia10III kernel: usbpd usbpd0: Type-C Source (default) connected
nov 20 22:36:02 Xperia10III kernel: QG-K: get_batt_id_ohm: batt_id_mv=241, batt_id_ohm=15000
nov 20 22:36:02 Xperia10III healthd: battery l=83 v=4224 t=30.6 h=2 st=3 c=214843 fc=4529000 cc=67 chg=
nov 20 22:36:02 Xperia10III kernel: pm7250b_charger: typec_attach_detach_irq_handler: IRQ: typec-attach-detach
nov 20 22:36:02 Xperia10III kernel: pm7250b_charger: typec_state_change_irq_handler: IRQ: cc-state-change; Type-C NONE detected
nov 20 22:36:02 Xperia10III kernel: pm7250b_charger: typec_state_change_irq_handler: typec_mode:0,Type-C NONE detected gpio84 set 1
nov 20 22:36:02 Xperia10III kernel: usbpd usbpd0: USB Type-C disconnect
nov 20 22:36:02 Xperia10III kernel: QG-K: get_batt_id_ohm: batt_id_mv=240, batt_id_ohm=15000
nov 20 22:36:02 Xperia10III mce[1996]: modules/battery-udev.c: mcebat_update(): charger_type: other -> none
nov 20 22:36:02 Xperia10III mce[1996]: modules/battery-udev.c: mcebat_update(): charger_state: on -> off
nov 20 22:36:02 Xperia10III mce[1996]: modules/battery-udev.c: mcebat_update(): battery_state: charging -> discharging
nov 20 22:36:02 Xperia10III healthd: battery l=83 v=4211 t=30.6 h=2 st=3 c=-394287 fc=4529000 cc=67 chg=
nov 20 22:36:02 Xperia10III kernel: pm7250b_charger: typec_state_change_irq_handler: IRQ: cc-state-change; Type-C SOURCE_HIGH detected
nov 20 22:36:02 Xperia10III kernel: usbpd usbpd0: Type-C Source (high - 3.0A) connected
nov 20 22:36:02 Xperia10III kernel: QG-K: get_batt_id_ohm: batt_id_mv=238, batt_id_ohm=15000
nov 20 22:36:02 Xperia10III healthd: battery l=83 v=4200 t=30.7 h=2 st=3 c=-389404 fc=4529000 cc=67 chg=
nov 20 22:36:02 Xperia10III kernel: QG-K: get_batt_id_ohm: batt_id_mv=239, batt_id_ohm=15000
nov 20 22:36:02 Xperia10III kernel: pm7250b_charger: smblib_usb_plugin_locked: IRQ: usbin-plugin attached
nov 20 22:36:02 Xperia10III healthd: battery l=83 v=4194 t=30.6 h=2 st=4 c=-550537 fc=4529000 cc=67 chg=
nov 20 22:36:02 Xperia10III kernel: binder: 7143 RLIMIT_NICE not set
nov 20 22:36:02 Xperia10III usb_moded[3131]: unknown connection type reported, assuming disconnected
nov 20 22:36:02 Xperia10III kernel: binder: 7364 RLIMIT_NICE not set
nov 20 22:36:02 Xperia10III mce[1996]: modules/battery-udev.c: mcebat_update(): charger_state: off -> on
nov 20 22:36:02 Xperia10III kernel: pm7250b_charger: smblib_set_icl_current: set ICL to 100000uA
nov 20 22:36:02 Xperia10III kernel: pm7250b_charger: smblib_set_icl_current: set ICL to 3000000uA
nov 20 22:36:02 Xperia10III healthd: battery l=83 v=4190 t=30.5 h=2 st=4 c=-439758 fc=4529000 cc=67 chg=a
nov 20 22:36:02 Xperia10III kernel: binder: 7362 RLIMIT_NICE not set
nov 20 22:36:02 Xperia10III kernel: binder: 7367 RLIMIT_NICE not set
nov 20 22:36:02 Xperia10III usb_moded[3131]: unhandled power supply type: USB_PD
nov 20 22:36:02 Xperia10III mce[1996]: modules/battery-udev.c: mcebat_update(): charger_type: none -> other
nov 20 22:36:02 Xperia10III mce[1996]: tklock.c: tklock_dbus_notification_beg_cb(): notification begin from name=:1.69 owner=:1.69 pid=5752 uid=100000 gid=996 priv=1 cmd=/usr/bin/lipstick -plugin evdevtouch -plugin evdevmouse -plugin
nov 20 22:36:03 Xperia10III kernel: pm7250b_charger: smblib_icl_change_work: icl_settled=500000
nov 20 22:36:03 Xperia10III healthd: battery l=83 v=4239 t=30.5 h=2 st=4 c=0 fc=4529000 cc=67 chg=a
nov 20 22:36:03 Xperia10III kernel: pm7250b_charger: chg_state_change_irq_handler: IRQ: chg-state-change
nov 20 22:36:03 Xperia10III kernel: QG-K: get_batt_id_ohm: batt_id_mv=244, batt_id_ohm=15000
nov 20 22:36:03 Xperia10III kernel: ALG: cap_learning_update: [SOMC CL][OFF] charge_status:1 bsoc_cp:8253
nov 20 22:36:03 Xperia10III healthd: battery l=83 v=4239 t=30.5 h=2 st=2 c=0 fc=4529000 cc=67 chg=a
nov 20 22:36:03 Xperia10III kernel: pm7250b_charger: somc_aicl_irq_handler: IRQ: input-current-limiting
nov 20 22:36:03 Xperia10III mce[1996]: modules/battery-udev.c: udevdevice_lookup_charger_type(): unknown charger type: USB_PD
nov 20 22:36:03 Xperia10III mce[1996]: modules/battery-udev.c: mcebat_update(): battery_state: discharging -> charging
nov 20 22:36:03 Xperia10III kernel: binder: 7326 RLIMIT_NICE not set
nov 20 22:36:03 Xperia10III kernel: QG-K: qg_somc_jeita_step_charge_work: [Charging] BSOC:8253 MSOC:83 RTEMP:304 IBATT:-114mA VBATT:4249mV VCELL:4247mV Target FCC:3250mA FV:4450mV
nov 20 22:36:03 Xperia10III kernel: pm7250b_charger: default_irq_handler: IRQ: usbin-collapse
nov 20 22:36:03 Xperia10III kernel: pm7250b_charger: somc_aicl_irq_handler: IRQ: aicl-done
nov 20 22:36:04 Xperia10III mce[1996]: modules/proximity.c: mp_datapipe_set_proximity_sensor_actual(): state: OPEN -> CLOSED
nov 20 22:36:04 Xperia10III kernel: sec_ts 1-0048: [sec_input] [P] tID:0 x:379 y:1177 z:40 major:10 minor:10 tc:1 type:0 noise:0
nov 20 22:36:04 Xperia10III kernel: QG-K: get_batt_id_ohm: batt_id_mv=249, batt_id_ohm=15000
nov 20 22:36:04 Xperia10III kernel: ALG: cap_learning_update: [SOMC CL][OFF] charge_status:1 bsoc_cp:8253
nov 20 22:36:04 Xperia10III healthd: battery l=83 v=4339 t=30.3 h=2 st=2 c=1244507 fc=4529000 cc=67 chg=a
nov 20 22:36:04 Xperia10III kernel: sec_ts 1-0048: [sec_input] [R] tID:0 mc:2 tc:0 lx:381 ly:1176 v:0100 cal:A2 id(0,0) p:0 noise:0 lp:(0)
nov 20 22:36:05 Xperia10III kernel: pm7250b_charger: smblib_icl_change_work: icl_settled=1700000
nov 20 22:36:05 Xperia10III healthd: battery l=83 v=4338 t=30.3 h=2 st=2 c=1221314 fc=4529000 cc=67 chg=a
nov 20 22:36:05 Xperia10III kernel: QG-K: qg_somc_jeita_step_charge_work: [Charging] BSOC:8253 MSOC:83 RTEMP:303 IBATT:-615mA VBATT:4291mV VCELL:4282mV Target FCC:1950mA FV:4450mV
nov 20 22:36:05 Xperia10III mce[1996]: modules/proximity.c: mp_datapipe_set_proximity_sensor_actual(): state: CLOSED -> OPEN
nov 20 22:36:06 Xperia10III kernel: binder: 7326 RLIMIT_NICE not set
nov 20 22:36:06 Xperia10III [1764]: [D] unknown:0 - Cache drop of item last used QDateTime(2022-11-20 07:59:23.000 CET Qt::TimeSpec(LocalTime))
nov 20 22:36:07 Xperia10III [1764]: [D] unknown:0 - Cache drop of item last used QDateTime(2022-11-20 07:59:23.000 CET Qt::TimeSpec(LocalTime))
nov 20 22:36:07 Xperia10III [1764]: [D] unknown:0 - Cache drop of item last used QDateTime(2022-11-20 07:59:24.000 CET Qt::TimeSpec(LocalTime))
nov 20 22:36:07 Xperia10III kernel: [schedu][0xaed54c8b6df][22:36:07.225100] wlan: [22257:I:OSIF] vdev 0, scan id 41356 type COMPLETED(1) reason COMPLETED(1) scan found 12 bss
nov 20 22:36:07 Xperia10III kernel: sec_ts 1-0048: [sec_input] [P] tID:0 x:632 y:668 z:35 major:9 minor:9 tc:1 type:0 noise:0
nov 20 22:36:07 Xperia10III kernel: sec_ts 1-0048: [sec_input] [R] tID:0 mc:16 tc:0 lx:676 ly:297 v:0100 cal:A2 id(0,0) p:0 noise:0 lp:(0)
nov 20 22:36:08 Xperia10III [1764]: [D] unknown:0 - Cache drop of item last used QDateTime(2022-11-20 07:59:24.000 CET Qt::TimeSpec(LocalTime))
nov 20 22:36:08 Xperia10III [1764]: [D] unknown:0 - Cache drop of item last used QDateTime(2022-11-20 07:59:25.000 CET Qt::TimeSpec(LocalTime))
nov 20 22:36:08 Xperia10III [1764]: [D] unknown:0 - Cache drop of item last used QDateTime(2022-11-20 07:59:26.000 CET Qt::TimeSpec(LocalTime))
nov 20 22:36:08 Xperia10III [1764]: [D] unknown:0 - Cache drop of item last used QDateTime(2022-11-20 07:59:27.000 CET Qt::TimeSpec(LocalTime))
nov 20 22:36:08 Xperia10III [1764]: [D] unknown:0 - Cache drop of item last used QDateTime(2022-11-20 07:59:28.000 CET Qt::TimeSpec(LocalTime))
nov 20 22:36:09 Xperia10III [1764]: [D] unknown:0 - Cache drop of item last used QDateTime(2022-11-20 07:59:28.000 CET Qt::TimeSpec(LocalTime))
nov 20 22:36:09 Xperia10III kernel: pm7250b_charger: smblib_set_icl_current: set ICL to 277000uA
nov 20 22:36:09 Xperia10III kernel: pm7250b_charger: somc_aicl_irq_handler: IRQ: aicl-done
nov 20 22:36:09 Xperia10III kernel: QG-K: get_batt_id_ohm: batt_id_mv=243, batt_id_ohm=15000
nov 20 22:36:09 Xperia10III kernel: ALG: cap_learning_update: [SOMC CL][OFF] charge_status:1 bsoc_cp:8253
nov 20 22:36:09 Xperia10III healthd: battery l=83 v=4342 t=30.5 h=2 st=2 c=1171570 fc=4529000 cc=67 chg=a
nov 20 22:36:09 Xperia10III healthd: battery l=83 v=4342 t=30.6 h=2 st=2 c=1171570 fc=4529000 cc=67 chg=a
nov 20 22:36:09 Xperia10III usb_moded[3131]: unhandled power supply type: USB_PD
nov 20 22:36:09 Xperia10III kernel: pm7250b_charger: smblib_set_icl_current: set ICL to 2000000uA
nov 20 22:36:09 Xperia10III kernel: QG-K: get_batt_id_ohm: batt_id_mv=242, batt_id_ohm=15000
nov 20 22:36:09 Xperia10III healthd: battery l=83 v=4234 t=30.5 h=2 st=2 c=-78735 fc=4529000 cc=67 chg=a
nov 20 22:36:09 Xperia10III healthd: battery l=83 v=4234 t=30.6 h=2 st=2 c=-78735 fc=4529000 cc=67 chg=a
nov 20 22:36:09 Xperia10III [1764]: [W] unknown:0 - libpng warning: iCCP: known incorrect sRGB profile
nov 20 22:36:09 Xperia10III kernel: binder: 7326 RLIMIT_NICE not set
nov 20 22:36:09 Xperia10III [1764]: [D] unknown:0 - Cache drop of item last used QDateTime(2022-11-20 18:41:21.000 CET Qt::TimeSpec(LocalTime))
nov 20 22:36:09 Xperia10III mce[1996]: tklock.c: tklock_datapipe_uiexception_type_cb(): uiexception_type = notif -> none
nov 20 22:36:09 Xperia10III kernel: pm7250b_charger: somc_aicl_irq_handler: IRQ: input-current-limiting
nov 20 22:36:09 Xperia10III kernel: QG-K: get_batt_id_ohm: batt_id_mv=255, batt_id_ohm=15000
nov 20 22:36:09 Xperia10III healthd: battery l=83 v=4369 t=30.1 h=2 st=2 c=1657105 fc=4529000 cc=67 chg=a
nov 20 22:36:10 Xperia10III [1764]: [D] unknown:0 - Cache drop of item last used QDateTime(2022-11-20 18:41:21.000 CET Qt::TimeSpec(LocalTime))
nov 20 22:36:10 Xperia10III kernel: pm7250b_charger: smblib_icl_change_work: icl_settled=1350000
nov 20 22:36:10 Xperia10III healthd: battery l=83 v=4401 t=30.1 h=2 st=2 c=1936036 fc=4529000 cc=67 chg=a
nov 20 22:36:11 Xperia10III kernel: sec_ts 1-0048: [sec_input] [P] tID:0 x:703 y:1374 z:34 major:8 minor:8 tc:1 type:0 noise:0
nov 20 22:36:11 Xperia10III kernel: sec_ts 1-0048: [sec_input] [R] tID:0 mc:2 tc:0 lx:702 ly:1373 v:0100 cal:A2 id(0,0) p:0 noise:0 lp:(0)
nov 20 22:36:11 Xperia10III [1764]: [D] openApp:245 - Open App 7992ed64-d77b-4841-a2ac-c5373a49d1ab
nov 20 22:36:11 Xperia10III mce[1996]: modules/proximity.c: mp_datapipe_set_proximity_sensor_actual(): state: OPEN -> CLOSED
nov 20 22:36:11 Xperia10III kernel: pm7250b_charger: somc_aicl_irq_handler: IRQ: input-current-limiting
nov 20 22:36:11 Xperia10III [1764]: [D] refresh:112 - Refreshing ApplicationData
nov 20 22:36:12 Xperia10III mce[1996]: modules/proximity.c: mp_datapipe_set_proximity_sensor_actual(): state: CLOSED -> OPEN
nov 20 22:36:12 Xperia10III kernel: binder: 7326 RLIMIT_NICE not set
nov 20 22:36:12 Xperia10III kernel: pm7250b_charger: smblib_icl_change_work: icl_settled=1450000
nov 20 22:36:12 Xperia10III healthd: battery l=83 v=4404 t=30.1 h=2 st=2 c=1965028 fc=4529000 cc=67 chg=a
nov 20 22:36:13 Xperia10III kernel: sec_ts 1-0048: [sec_input] [P] tID:0 x:622 y:541 z:35 major:9 minor:9 tc:1 type:0 noise:0
nov 20 22:36:13 Xperia10III kernel: sec_ts 1-0048: [sec_input] [R] tID:0 mc:15 tc:0 lx:655 ly:120 v:0100 cal:A2 id(0,0) p:0 noise:0 lp:(0)
nov 20 22:36:13 Xperia10III mce[1996]: modules/proximity.c: mp_datapipe_set_proximity_sensor_actual(): state: OPEN -> CLOSED
nov 20 22:36:13 Xperia10III mce[1996]: modules/proximity.c: mp_datapipe_set_proximity_sensor_actual(): state: CLOSED -> OPEN
nov 20 22:36:13 Xperia10III kernel: QG-K: qg_somc_jeita_step_charge_work: [Charging] BSOC:8253 MSOC:83 RTEMP:301 IBATT:-1706mA VBATT:4382mV VCELL:4357mV Target FCC:1300mA FV:4450mV
nov 20 22:36:14 Xperia10III mce[1996]: modules/proximity.c: mp_datapipe_set_proximity_sensor_actual(): state: CLOSED -> UNDEF
nov 20 22:36:14 Xperia10III kernel: QG-K: get_batt_id_ohm: batt_id_mv=252, batt_id_ohm=15000
nov 20 22:36:14 Xperia10III healthd: battery l=83 v=4362 t=30.2 h=2 st=2 c=1406251 fc=4529000 cc=67 chg=a
nov 20 22:36:14 Xperia10III kernel: ALG: cap_learning_update: [SOMC CL][OFF] charge_status:1 bsoc_cp:8253
nov 20 22:36:15 Xperia10III kernel: binder: 7326 RLIMIT_NICE not set
nov 20 22:36:15 Xperia10III kernel: sec_ts 1-0048: [sec_input] [P] tID:0 x:858 y:12 z:14 major:3 minor:3 tc:1 type:0 noise:0
nov 20 22:36:16 Xperia10III kernel: sec_ts 1-0048: [sec_input] [R] tID:0 mc:100 tc:0 lx:954 ly:0 v:0100 cal:A2 id(0,0) p:0 noise:0 lp:(0)
nov 20 22:36:17 Xperia10III kernel: sec_ts 1-0048: [sec_input] [P] tID:0 x:990 y:9 z:13 major:3 minor:3 tc:1 type:0 noise:0
nov 20 22:36:17 Xperia10III kernel: sec_ts 1-0048: [sec_input] [R] tID:0 mc:52 tc:0 lx:859 ly:390 v:0100 cal:A2 id(0,0) p:0 noise:0 lp:(0)
nov 20 22:36:18 Xperia10III lipstick[5752]: [D] onDestruction:268 - coverActionIndicators destroyed store-client.desktop
nov 20 22:36:18 Xperia10III [1764]: [D] onUiClosed:178 - UI was closed
nov 20 22:36:18 Xperia10III kernel: binder: 7326 RLIMIT_NICE not set
nov 20 22:36:19 Xperia10III kernel: sec_ts 1-0048: [sec_input] [P] tID:0 x:760 y:1591 z:38 major:10 minor:10 tc:1 type:0 noise:0
nov 20 22:36:19 Xperia10III kernel: sec_ts 1-0048: [sec_input] [R] tID:0 mc:6 tc:0 lx:759 ly:1586 v:0100 cal:A2 id(0,0) p:0 noise:0 lp:(0)
nov 20 22:36:19 Xperia10III invoker[6423]: WARNING: An inactive plugin is misbehaving - tried to show a window!
nov 20 22:36:19 Xperia10III invoker[6423]: WARNING: requestActivate() called for  QQuickView(0x3b7f5760)  which has Qt::WindowDoesNotAcceptFocus set.
nov 20 22:36:20 Xperia10III kernel: qcom_rpmh DRV:apps_rsc TCS Busy, retrying RPMH message send: addr=0x30010
nov 20 22:36:21 Xperia10III kernel: binder: 7326 RLIMIT_NICE not set
nov 20 22:36:21 Xperia10III kernel: [schedu][0xaed653bc32d][22:36:21.599996] wlan: [22257:I:OSIF] scan start scan id 41357
nov 20 22:36:22 Xperia10III mce[1996]: tklock.c: tklock_datapipe_uiexception_type_cb(): uiexception_type = none -> notif
nov 20 22:36:23 Xperia10III mce[1996]: modules/proximity.c: mp_datapipe_set_proximity_sensor_actual(): state: UNDEF -> OPEN
nov 20 22:36:23 Xperia10III mce[1996]: tklock.c: tklock_dbus_notification_beg_cb(): notification begin from name=:1.69 owner=:1.69 pid=5752 uid=100000 gid=996 priv=1 cmd=/usr/bin/lipstick -plugin evdevtouch -plugin evdevmouse -plugin
nov 20 22:36:23 Xperia10III lipstick[5752]: [D] displayNotification:547 - Warning: Notification has both preview summary and preview body but no actions. Remove the preview body or add an action: System  Skärmklipp taget Skärmklipp_20221120_001.png
This time when it came back, it was broken (which i haven’t seen much before):
Thanks for the report @attah. I’ve been trying to reproduce this, but unfortuantely without success (landscape, split-keyboard). Can you think of any other details (e.g. site that you’re visiting; search phrase you’re entering) that might be required for this to happen?
Without being able to reproduce the bug it will be very hard to resolve I’m afraid, so any hints you can think of would be appreciated.
I’ll give it a think… The plain black page happens without any input - but input closes the keyboard from being in that state.
Thanks for clarifying. I’m not able to reproduce either unfortunately. I guess I may have to create 100 bookmarks to test it properly…
It happens when you use cover page ‘+’ to open new tab of already running browser from homepage in landscape. So 100% reproducible for me on XIII:
  1. Open browser
  2. Swipe back to homescreen
  3. Turn phone sideways
  4. Open new tab from cover
  5. Type a letter
