The referenced LXD related discussion on problems with bluetooth within container is about seven years old. Maybe the related defitiencies within the linux kernel have been modernized by now?
Anyway. In the LXD issue tracker this issue was closed in may 2017 and a reasonable workaround was pointed out that makes use of libusb’s userlevel bluetooth stack in conjunction with the usb device type.
So maybe there could be a comparable solution in our case with alien dalvik? Having to plug a USB BT dongle into the phones USB-C in order to rent e-scooters or set up solar inverters surely would be a no issue at all. It would indeed remove one of the bigger pain points
This will be a showstopper for me for using Jolla and I would have to say goodbye to Sailfish, even though I have been there from the very beginning.
There is a patch which was not merged:
https://lore.kernel.org/lkml/20170814071640.289327-1-fupan.li@windriver.com/
+1 for the feature request.
I finally found today, what is causing me so much trouble and making me carry around second phone with android that pairs to all those apps that run well on SFOS app support, but for some strange reason do not pair with the devices because of which I have them. This is it.
Could you explain it in detail. I’m interested, but I don’t understand what you mean.
He means that he did not realize the lack of the feature “Bluetooth in App Support” before he read this thread, after months of trying to connect devices
I’ve linked these before, but for the sake of stirring curiousity:
First, docker specific, but docker uses the kernels cgroups foo:
LXC specific
No idea how far any of this gets us since I have no idea how jolla sets up lxc for the android layer.
I remembered this feature, a few years after stopping using sailfish os due to that exact feature missing (public buses are using it, their app is no longer locked so bad that i couldn’t use it, but the bluetooth is a must) and someone here was nice enough (lunatic, that just doesn’t understand, that some features are a must - due to the external factors forcing you, not using buses due to sailfish is just a deal breaker) to pushed me into it.
Nice to see my decision was correct, now I am happy Pixel and GrapheneOS user, while I hate google and would be happy with alternative and would prefer sailfish but not with company that is so badly ignoring users needs.
For, 5 years.
You are just not getting it, sailfish, although technologically better, than android, is not a market leader, rather market follower and critical features of android, affecting real life usage, are something that should be top priority, not pushed to the side, even if it means hiring someone who can do it.
I no longer think that this project has any future. Not due technology, due to bad management and priorities.
@stiray I understand your issue, thats why I have an android phone in my bag if I have to use bluetooth/bank software. But did you see: Potential Bluetooth Support in the Android App Support (AAS) - #206 by rdomschk ? The bluetooth issue could be solved for you?
You are so right. What sense does SF make for us all, when you cannot buy a bus ticket?
Experiences of using Pelago electric bike with Mahle 30X motor and its application. Bluetooth connection mostly fails. In the best case, it is possible to get connection after a couple attempts as a new bike, and in the result see total mileage, battery level and general info about the bike which is recognised correctly. People tell that route tracking and other features work fine with Android phones. The guys in Pelago shop suggested that I am possibly the only person in the world that uses Jolla + the Mahle motor in bike so they could not help much. But perhaps among you there is another user, with similar or different experiences? ChatGPT had some ideas but I would not like to use extremely much time for logging and debuging of this Bluetooth issue … And yes, the new Jolla phone, with the version 5.2.0.15 - 16. Just updating to 5.2.0.17. Edit: additional question - is there relation between the location service switch on/off and bluetooth on/off? When moving on a bike or car, one could expect that in addition to bluetooth the location needs to be known well.
Hi,
you’re not the only one on this planet ![]()
I’m using the Mahle X20 with the Mahle app installed on a Sony Xperia 10 II. It mostly works, but I use it only to configure the motor, not to track routes with it. What I’ve noticed is that if BT is swithed off it takes some time for AAS to find the motor after switching BT on - seems there’s a delay before BT becomes available in AAS.
I will try to track routes in the next days to confirm whether that works or not.
Edit: Tested yesterday, route tracking works as well as long as Location Services are activated. Otherwise the route cannot be tracked as the Mahle motor doesn’t provide GPS data.
Thanks @tmichel , I’ll continue testing next week, taking care both BT and location settings, order of switching on BT, Mahle application in Jolla, bike itself. Perhaps it will be necessary to restart BT services, clean old cache etc.
Route tracking now works with Mahle application. Bluetooth connection still does not “find my bike” but after a couple of tries finds it as a new bike. Did several things: learned to activate full accuracy of location (long press on the location icon and then settings), updated Mahle app, checked everything. Recorded by Mahle routes and other data appear nicely via their web interface. Bluetooth issues will hopefully be solved with next Sailfish updates.
