Bluetooth Keyboard does not work in Android Apps
REPRODUCIBILITY: Always
OS VERSION: 5.0.0.67
HARDWARE: Xperia 10 II
UI LANGUAGE: German
REGRESSION: No
Paired bluetooth keyboard is recognized in Android Apps, the virtual keyboard is not activated when i tap on an input field. But the characters typed do not appear in the edit field. Usage in Sailfish OS apps works as expected.
Paired bluetooth keyboard.
  1. Turn on Bluetooth
  2. Open Sailfish app, for example notes app, keyboard works, text input as expected
  3. Switch to Android app, tap on edit field, no virtual keyboard is shown, typing does not give characters in the edit field.
Characters appear in the edit field of the Android app
Noc characters appear, no virtual keyboard
None
I have the same issue on Sony Xperia 10 III. According to this post the problem was fixed in 5.0.0.55. However, it has returned in 5.0.0.67
Thanks for reporting.
A Jolla-internal bug was filed on this issue.
Xperia 10 III 5.0.0.72
I did not encounter this problem before but also did not use my Bluetooth keyboard for a while. Today I noticed the effect described above for the very first time.
It worked before but always switched to American layout with Android apps.
(I am a SF user since 1954 and will give up on all electronic devices if this is not fixed within 48hrs :smiling_face_with_three_hearts:)
