REPRODUCIBILITY: 100%
OS VERSION: 5.1.0.8
HARDWARE: Xperia 10 II
UI LANGUAGE: French
REGRESSION: Yes
Bluetooth headset/headphones which were working perfectly until and including 5.0.x can be paired and connected to the phone, but there is no audio output.
Install 5.1.0.8, pair and connect the bluetooth headset, then try to use it, e.g. play some music
Install 5.1.0.8 on Xperia 10 ii via Settings
Connect the bluetooth device (or delete it and pair it again, no change)
Try to play something (anything) from the phone, such as music or videos
Audio output from the headphones
Audio output still from the built-in speaker, not the headphones
None. Installing or uninstalling the AppSupport Bluetooth app from the Jolla Store changes nothing about this behaviour
I already tried:
Rebooting
Unpairing and re-pairing of the Bluetooth device
Changing the ‘class’ of the Bluetooth device back and forth (Headset/Multimedia, etc)
Installing and uninstalling AAS Bluetooth
Connecting and disconnecting the Bluetooth device every now and then
Thank you for the report! It would be useful if you could provide some logs. I’m assuming you use the headset exclusively in SFOS, but did you install the new AppSupport Bluetooth?
Also, I think having some logs would help developers. Even if you didn’t install AAS Bluetooth, you will find good instructions here:
