REPRODUCIBILITY: always
BUILD ID = OS VERSION: 4.1.0.24
HARDWARE: XA2
UI LANGUAGE: German
REGRESSION: Yes
I am able to pair my Pebble Time but it immediately disconnects right after connection. Any help is appreciated.
- Pair Pebble Time
- Connect to Pebble Time
The connection should stay alive and be usable as before.
The connections immediately drops.
When connection via bluetoothctl the following error appears:
Failed to connect: org.bluez.Error.NotAvailable
btmon output
Bluetooth monitor ver 5.54
= New Index: 38:78:62:47:D1:38 (Primary,Virtual,hci0) [hci0] 0.762082
= Open Index: 38:78:62:47:D1:38 [hci0] 0.762088
= Index Info: 38:78:62:47:D1:38 (Qualcomm) [hci0] 0.762089
< HCI Command: Create Connection (0x01|0x0005) plen 13 #1 [hci0] 34.041155
Address: B0:B4:48:9B:88:10 (Texas Instruments)
Packet type: 0xcc18
DM1 may be used
DH1 may be used
DM3 may be used
DH3 may be used
DM5 may be used
DH5 may be used
Page scan repetition mode: R2 (0x02)
Page scan mode: Mandatory (0x00)
Clock offset: 0x0000
Role switch: Allow slave (0x01)
> HCI Event: Command Status (0x0f) plen 4 #2 [hci0] 34.063729
Create Connection (0x01|0x0005) ncmd 1
Status: Success (0x00)
> HCI Event: Connect Complete (0x03) plen 11 #3 [hci0] 34.467286
Handle: 4
Link type: ACL (0x01)
Encryption: Disabled (0x00)
< HCI Command: Read Remote Supporte.. (0x01|0x001b) plen 2 #4 [hci0] 34.468386
Handle: 4
> HCI Event: Connection Packet Type Changed (0x1d) plen 5 #5 [hci0] 34.473905
Handle: 4
Packet type: 0x3318
DM1 may be used
DH1 may be used
2-DH3 may not be used
3-DH3 may not be used
2-DH5 may not be used
3-DH5 may not be used
> HCI Event: Command Status (0x0f) plen 4 #6 [hci0] 34.476129
Read Remote Supported Features (0x01|0x001b) ncmd 1
> HCI Event: Read Remote Supported Features (0x0b) plen 11 #7 [hci0] 34.478112
Handle: 4
Features: 0xff 0xfe 0x2d 0x7e 0xd8 0x1f 0x7b 0x87
3 slot packets
5 slot packets
Encryption
Slot offset
Timing accuracy
Role switch
Hold mode
Sniff mode
Power control requests
Channel quality driven data rate (CQDDR)
SCO link
HV2 packets
HV3 packets
u-law log synchronous data
A-law log synchronous data
CVSD synchronous data
Power control
Transparent synchronous data
Flow control lag (middle bit)
Enhanced Data Rate ACL 2 Mbps mode
Enhanced Data Rate ACL 3 Mbps mode
Enhanced inquiry scan
Interlaced inquiry scan
Interlaced page scan
RSSI with inquiry results
AFH capable slave
AFH classification slave
LE Supported (Controller)
3-slot Enhanced Data Rate ACL packets
5-slot Enhanced Data Rate ACL packets
Sniff subrating
Pause encryption
AFH capable master
AFH classification master
Extended Inquiry Response
Simultaneous LE and BR/EDR (Controller)
Secure Simple Pairing
Encapsulated PDU
Erroneous Data Reporting
Non-flushable Packet Boundary Flag
Link Supervision Timeout Changed Event
Inquiry TX Power Level
Enhanced Power Control
Extended features
< HCI Command: Read Remote Extended.. (0x01|0x001c) plen 3 #8 [hci0] 34.478254
Handle: 4
Page: 1
> HCI Event: Connection Packet Type Changed (0x1d) plen 5 #9 [hci0] 34.479212
Handle: 4
Packet type: 0x331c
3-DH1 may not be used
DM1 may be used
DH1 may be used
> HCI Event: Connection Packet Type Changed (0x1d) plen 5 #10 [hci0] 34.481483
Handle: 4
Packet type: 0x330b
2-DH1 may not be used
DM1 may be used
Unknown packet types (0x0001)
> HCI Event: Connection Packet Type Changed (0x1d) plen 5 #11 [hci0] 34.482289
Handle: 4
Packet type: 0x3318
DM1 may be used
DH1 may be used
> HCI Event: Max Slots Change (0x1b) plen 3 #12 [hci0] 34.486195
Handle: 4
Max slots: 5
> HCI Event: Command Status (0x0f) plen 4 #13 [hci0] 34.486594
Read Remote Extended Features (0x01|0x001c) ncmd 1
> HCI Event: Read Remote Extended Features (0x23) plen 13 #14 [hci0] 34.494660
Handle: 4
Page: 1/1
Features: 0x03 0x00 0x00 0x00 0x00 0x00 0x00 0x00
Secure Simple Pairing (Host Support)
LE Supported (Host)
< HCI Command: Remote Name Request (0x01|0x0019) plen 10 #15 [hci0] 34.495053
< ACL Data TX: Handle 4 flags 0x00 dlen 10 #16 [hci0] 34.495108
L2CAP: Information Request (0x0a) ident 1 len 2
Type: Extended features supported (0x0002)
> HCI Event: Command Status (0x0f) plen 4 #17 [hci0] 34.498746
Remote Name Request (0x01|0x0019) ncmd 1
> HCI Event: Number of Completed Packets (0x13) plen 5 #18 [hci0] 34.502492
Num handles: 1
Handle: 4
Count: 1
> ACL Data RX: Handle 4 flags 0x02 dlen 16 #19 [hci0] 34.504265
L2CAP: Information Response (0x0b) ident 1 len 8
Result: Success (0x0000)
Features: 0x00000280
Fixed Channels
Unicast Connectionless Data Reception
< ACL Data TX: Handle 4 flags 0x00 dlen 10 #20 [hci0] 34.504377
L2CAP: Information Request (0x0a) ident 2 len 2
Type: Fixed channels supported (0x0003)
> HCI Event: Remote Name Req Complete (0x07) plen 255 #21 [hci0] 34.506429
Name: Pebble Time 8810
@ Device Connected: B0:B4:48:9B:88:10 (0) flags 0x0000
11 09 50 65 62 62 6c 65 20 54 69 6d 65 20 38 38 ..Pebble Time 88
31 30 10
> HCI Event: Number of Completed Packets (0x13) plen 5 #22 [hci0] 34.509299
Num handles: 1
Handle: 4
Count: 1
> ACL Data RX: Handle 4 flags 0x02 dlen 20 #23 [hci0] 34.512367
L2CAP: Information Response (0x0b) ident 2 len 12
Channels: 0x0000000000000006
L2CAP Signaling (BR/EDR)
Connectionless reception
< ACL Data TX: Handle 4 flags 0x00 dlen 12 #24 [hci0] 34.512538
L2CAP: Connection Request (0x02) ident 3 len 4
PSM: 1 (0x0001)
Source CID: 64
> HCI Event: Number of Completed Packets (0x13) plen 5 #25 [hci0] 34.516629
Num handles: 1
Handle: 4
Count: 1
> ACL Data RX: Handle 4 flags 0x02 dlen 16 #26 [hci0] 34.519036
L2CAP: Connection Response (0x03) ident 3 len 8
Destination CID: 94
Source CID: 64
Result: Connection successful (0x0000)
Status: No further information available (0x0000)
< ACL Data TX: Handle 4 flags 0x00 dlen 12 #27 [hci0] 34.519221
L2CAP: Configure Request (0x04) ident 4 len 4
Destination CID: 94
Flags: 0x0000
> ACL Data RX: Handle 4 flags 0x02 dlen 16 #28 [hci0] 34.520868
L2CAP: Configure Request (0x04) ident 42 len 8
Destination CID: 64
Flags: 0x0000
Option: Maximum Transmission Unit (0x01) [mandatory]
MTU: 339
< ACL Data TX: Handle 4 flags 0x00 dlen 18 #29 [hci0] 34.520970
L2CAP: Configure Response (0x05) ident 42 len 10
Source CID: 94
Flags: 0x0000
MTU: 339
> HCI Event: Number of Completed Packets (0x13) plen 5 #30 [hci0] 34.527112
Num handles: 1
Handle: 4
Count: 1
> HCI Event: Number of Completed Packets (0x13) plen 5 #31 [hci0] 34.530337
Num handles: 1
Handle: 4
Count: 1
> ACL Data RX: Handle 4 flags 0x02 dlen 14 #32 [hci0] 34.531161
L2CAP: Configure Response (0x05) ident 4 len 6
Source CID: 64
Flags: 0x0000
< ACL Data TX: Handle 4 flags 0x00 dlen 24 #33 [hci0] 34.531491
Channel: 94 len 20 [PSM 1 mode Basic (0x00)] {chan 0}
SDP: Service Search Attribute Request (0x06) tid 0 len 15
Search pattern: [len 5]
Sequence (6) with 3 bytes [8 extra bits] len 5
UUID (3) with 2 bytes [0 extra bits] len 3
L2CAP (0x0100)
Max record count: 65535
Attribute list: [len 7]
Sequence (6) with 5 bytes [8 extra bits] len 7
Unsigned Integer (1) with 4 bytes [0 extra bits] len 5
0x0000ffff
Continuation state: 0
> HCI Event: Number of Completed Packets (0x13) plen 5 #34 [hci0] 34.538610
Num handles: 1
Handle: 4
Count: 1
> ACL Data RX: Handle 4 flags 0x02 dlen 96 #35 [hci0] 34.542113
Channel: 64 len 92 [PSM 1 mode Basic (0x00)] {chan 0}
SDP: Service Search Attribute Response (0x07) tid 0 len 87
Attribute bytes: 84
Attribute list: [len 80] {position 0}
Attribute: Service Record Handle (0x0000) [len 2]
0x0001000a
Attribute: Service Class ID List (0x0001) [len 2]
UUID (3) with 16 bytes [0 extra bits] len 17
00000000-deca-fade-deca-deafdecacaff
Serial Port (0x1101)
Attribute: Protocol Descriptor List (0x0004) [len 2]
L2CAP (0x0100)
RFCOMM (0x0003)
Unsigned Integer (1) with 1 byte [0 extra bits] len 2
0x01
Attribute: Unknown (0x0100) [len 2]
Serial Port Server Port 6 [len 25]
< ACL Data TX: Handle 4 flags 0x00 dlen 24 #36 [hci0] 34.549766
SDP: Service Search Attribute Request (0x06) tid 1 len 15
PnP Information (0x1200)
0x0000ffff
> HCI Event: Number of Completed Packets (0x13) plen 5 #37 [hci0] 34.556775
Num handles: 1
Handle: 4
Count: 1
> ACL Data RX: Handle 4 flags 0x02 dlen 67 #38 [hci0] 34.561962
Channel: 64 len 63 [PSM 1 mode Basic (0x00)] {chan 0}
SDP: Service Search Attribute Response (0x07) tid 1 len 58
Attribute bytes: 55
Attribute list: [len 51] {position 0}
0x0001000b
Attribute: Unknown (0x0200) [len 2]
0x0103
Attribute: Unknown (0x0201) [len 2]
0x005e
Attribute: Unknown (0x0202) [len 2]
0x0001
Attribute: Unknown (0x0203) [len 2]
0x0112
Attribute: Unknown (0x0204) [len 2]
true
Attribute: Unknown (0x0205) [len 2]
0x0001
> HCI Event: Connection Packet Type Changed (0x1d) plen 5 #39 [hci0] 36.274681
Handle: 4
Packet type: 0x3308
DM1 may be used
< ACL Data TX: Handle 4 flags 0x00 dlen 12 #40 [hci0] 36.997001
L2CAP: Disconnection Request (0x06) ident 5 len 4
Destination CID: 94
Source CID: 64
> HCI Event: Number of Completed Packets (0x13) plen 5 #41 [hci0] 37.027596
Num handles: 1
Handle: 4
Count: 1
> ACL Data RX: Handle 4 flags 0x02 dlen 12 #42 [hci0] 37.049566
L2CAP: Disconnection Response (0x07) ident 5 len 4
Destination CID: 94
Source CID: 64
< HCI Command: Disconnect (0x01|0x0006) plen 3 #43 [hci0] 39.052935
Handle: 4
Reason: Remote User Terminated Connection (0x13)
> HCI Event: Command Status (0x0f) plen 4 #44 [hci0] 39.061528
Disconnect (0x01|0x0006) ncmd 1
> HCI Event: Disconnect Complete (0x05) plen 4 #45 [hci0] 39.218555
Handle: 4
Reason: Connection Terminated By Local Host (0x16)
@ Device Disconnected: B0:B4:48:9B:88:10 (0) reason 2
