Is there any app or any other way to identify the battery level of the connected bluetooth earphones?
Unfortunately no
The information is there, but not being parsed by anything as far as i can tell.
I.e. I have seen AT+IPHONEACCEV in the journal log, but it doesnāt appear to be captured by anything.
To me it appears like it would be easy to capture and expose on dbus for somebody that is āat homeā in the Bluetooth subsystem. But i guess the main question is how to make it work with upstream and make the functionality maintainable through future changes in the area.
This used to work in older versions , however one of the 1.1x updates broke it and itās broken ever since.
Wow! Is there any info on this somewhere?
Maybe this could be brought up here:
ā¦or perhaps next time around.
Edit: wrong link
It seems BlueZ will finally start exposing easily accessible battery readings among the normal D-Bus properties.
SFOS seems to be tracking upstream BlueZ pretty close, so hopefully this can be included in not too long.
Plumbing it in to the GUI should then become almost trivial
@attah Are there any news on this?
Hmm, looks like we should already have it +/- build and configuration options.
(And another update landed in the repos just last week, presumably in preparation for 4.6).
I already had a leftover attempt at enabling it in the config file, and i have now added the command line switch to the systemd unit. I have rebuilt the package(s) with --enable-experimental, and i have even removed some of the code that skips experimental attributes. Still nothing for my headphones.
Then i tried my mouse - and there it was. So now i need to step back all the changes and see what actually did it - if anything.
The exact same command that didnāt get me any battery status for my headphones on the phone does work on my computer. The source was listed as āApple accessory indicationā, no less⦠so compatibility should be great. But there iām actually one version behind current SFOS. Iāll have to keep digging for the difference another dayā¦
Edit: After googling a bit just now, i refreshed my memory. This needs a new Pulseaudio. And newer still than the stalled upgrade to 15. Itās so backwards that it failed to stick in my memory i guess. Might be backportable, might be a trivial uplift when 15 gets picked back up⦠not sure.
I got some Infos for my Sony In-Ears:
[defaultuser@XperiaXZ2Compact ~]$ bluetoothctl
Failed to register agent: org.freedesktop.DBus.Error.AuthFailed
[WF-C500]# info
Device 30:53:C1:E6:70:51 (public)
Alias: WF-C500
Class: 0x00240404
Icon: audio-headset
Paired: yes
Bonded: yes
Trusted: yes
Blocked: no
Connected: yes
LegacyPairing: no
UUID: Vendor specific (00000000-deca-fade-deca-deafdecacaff)
UUID: Headset (00001108-0000-1000-8000-00805f9b34fb)
UUID: Audio Sink (0000110b-0000-1000-8000-00805f9b34fb)
UUID: A/V Remote Control Target (0000110c-0000-1000-8000-00805f9b34fb)
UUID: Advanced Audio Distribu.. (0000110d-0000-1000-8000-00805f9b34fb)
UUID: A/V Remote Control (0000110e-0000-1000-8000-00805f9b34fb)
UUID: Handsfree (0000111e-0000-1000-8000-00805f9b34fb)
UUID: PnP Information (00001200-0000-1000-8000-00805f9b34fb)
UUID: Vendor specific (764cbf0d-bbcb-438f-a8bb-6b92759d6053)
UUID: Vendor specific (8901dfa8-5c7e-4d8f-9f0c-c2b70683f5f0)
UUID: Vendor specific (956c7b26-d49a-4ba8-b03f-b17d393cb6e2)
Modalias: usb:v054Cp0DD4d1000
Pressed Pause:
[CHG] Transport /org/bluez/hci0/dev_30_53_C1_E6_70_51/sep1/fd17 State: idle
Pressed Play:
[CHG] Transport /org/bluez/hci0/dev_30_53_C1_E6_70_51/sep1/fd17 State: active
Increase Volume 3 times:
[CHG] Transport /org/bluez/hci0/dev_30_53_C1_E6_70_51/sep1/fd17 Volume: 0x004f (79)
[CHG] Transport /org/bluez/hci0/dev_30_53_C1_E6_70_51/sep1/fd17 Volume: 0x0053 (83)
[CHG] Transport /org/bluez/hci0/dev_30_53_C1_E6_70_51/sep1/fd17 Volume: 0x0057 (87)
A decreasing battery level should be automatically notified.
I am trying to find the UUID and key from which I can read the actual battery level.
Status: RUNNING
Beschreibung: WF-C500
Treiber: module-bluez5-device.c
Abtastwert-Angabe: s16le 2ch 44100Hz
Kanalzuordnung: front-left,front-right
Besitzer-Modul: 41
Stumm: nein
LautstƤrke: front-left: 65536 / 100% / 0,00 dB, front-right: 65536 / 100% / 0,00 dB
Verteilung 0,00
Basis-LautstƤrke: 65536 / 100% / 0,00 dB
Quellen-Monitor: bluez_sink.30_53_C1_E6_70_51.a2dp_sink.monitor
Latenz: 50159 usec, eingestellt 45317 usec
Flags: HARDWARE DECIBEL_VOLUME LATENCY
Eigenschaften:
bluetooth.protocol = "a2dp_sink"
device.description = "WF-C500"
device.string = "30:53:C1:E6:70:51"
device.api = "bluez"
device.class = "sound"
device.bus = "bluetooth"
device.form_factor = "headset"
bluez.path = "/org/bluez/hci0/dev_30_53_C1_E6_70_51"
bluez.class = "0x240404"
bluez.alias = "WF-C500"
device.icon_name = "audio-headset-bluetooth"
device.intended_roles = "phone"
x-maemo.mode = "bta2dp"
x-maemo.accessory_hwid = ""
Ports:
headset-output: Headset (type: Headset, priority: 0, available)
Aktiver Port: headset-output
Formate:
pcm
I did not understand why they hide such important information like battery level.
I donāt think you will have much luck querying the battery level that way (beyond what Bluez is already capable to, possibly after setting flags). I.e. If your device is as well-behaved as my mouse, you can get it - but so can Bluez. However, for a lot of headphones it seems to use this iPhone accessory stuff that needs help in Pulse.
Please use code blocks when pasting logs.
I have now reverted all my changes on the phone, and it seems that i still have the battery service, though with one attribute less.
gdbus introspect --system --dest org.bluez --object-path /org/bluez/hci0/dev_E8_0E_8D_62_88_72 -r -p
interface org.bluez.Battery1 {
properties:
readonly y Percentage = 0x64;
And after setting Experimental = true in /etc/bluetooth/main.conf.
properties:
readonly s Source = 'GATT Battery Service';
And of course 0x64 = 100.
So it seems we have all we need here, except downstream stuff like Pulse reporting back to Bluez the battery status they (for whatever reason) get hold of.
Maybe things improve with the next Update:
- mal is working on upgrading
pulseaudioto 17.0, and updated the build in modules in the preparation for it:- in
pulseaudio-modules-nemo,- in
pulseaudio-policy-enforcement,- and in
pulseaudio-modules-keepalive.
Well this would be a great feature I do miss.
Thumbs up!
So still no news on this topic
I have left Sailfish OS for a few years and waiting to hop on the boat again with Jolla 2. But still no solution for this?
With updated Pulseaudio and Bluez in 5.1 we should have all tools.
hopefully after 5.2 Jolla can start to focus more on UI feature stuff. I understand they have small team and they are too busy with the Jolla Phone and stuff
Unfortunately we donāt. Bluez is compiled without -experimental flag and even if it is it will not work with BT modules compiled into kernel. So, forget about Bluetooth power level at the moment.
At least we have a native app for Sony headphones:
