Fair, I’d assumed the frozen SPL was known and mostly wanted the numbers pinned to my
own build instead of leaving it at “seems stale”. The answer I was actually after was
that the adaptation does not receive vendor updates. That reframes it usefully.
If the vendor layer is shipped once and never revised, the SPL is frozen by
construction and not by neglect. There is also no mainline path to route around it,
since the SoC has no upstream DTS. That is worth stating plainly for anyone weighing the
device.
What that means concretely
The gap is structural and not a scheduling problem:
- Reeder and Unisoc shipped the Android 13 vendor layer once, at SPL 2023-09-05.
- Jolla builds Sailfish on top and rebuilds the Jolla repos, which is measurable and
current.
vendor, odm and the kernel come from the vendor BSP with no update channel.
So the userspace moves and the substrate does not.
Measured on a 5.2.0.22 C2
| Item |
Value |
ro.build.version.security_patch |
2023-09-05 |
ro.vendor.build.security_patch |
2023-09-05 |
ro.odm.build.date |
2025-02-18 |
ro.build.version.release |
13 (SDK 33, VNDK 33) |
| Package count |
900 |
| Median package build date |
2026-06-04 |
openssl-libs |
3.5.7+git1 (Jun 2026) |
openssh |
10.3p1+git1 (Jun 2026) |
| Kernel |
5.4.233-android12-9-gb29821c820b3 |
Note that ro.odm.build.date is 2025-02-18 while the declared SPL is 2023-09-05. The
layer was rebuilt without rebasing the security baseline.
Why it matters
- Android AppSupport runs on a 2023-09 codebase. Codec, media and Bluetooth parsing
bugs from the last two years are unpatched. That surface is reachable by browsing or
by joining a hostile network.
- The kernel is a 5.4 BSP build with no mainline path, and
unprivileged_bpf_disabled
is 0.
- It will not improve. No vendor channel, no upstream DTS, so no independently
maintained kernel. The remedy is new hardware.
None of this is a criticism of the Sailfish work, which is current and which I can
measure. It is a property of the reference-board arrangement.
None of it is covered
The patch level is not a cosmetic detail, and it is not only the vendor layer. Every
Android bulletin since 2023-09 is missing from this build:
| Period |
CVEs published |
Applied here |
| up to 2023-09 |
to |
yes |
| 2023-10 to 2025-09 |
956 |
none |
Nine hundred and fifty-six published CVEs, none applied. That is the size of the gap.
A confirmed match, not a count
CVE-2025-48543 is a use-after-free in Android Runtime. Local escalation of privilege,
no additional execution privileges needed, no user interaction needed for exploitation.
CISA added it to the known-exploited list on 2025-09-04.
The AOSP advisory lists the updated AOSP versions as 13, 14, 15 and 16. This device
reports ro.build.version.sdk = 33, which is Android 13, at SPL 2023-09-05. The fix
shipped in the 2025-09 bulletin. The vulnerable ART code is present because it is the
build’s own runtime.
Known-exploited Android CVEs absent from this build
From the CISA KEV feed, Android entries added after 2023-09:
| Date |
CVE |
Type |
| 2024-03-05 |
CVE-2023-21237 |
Pixel information disclosure |
| 2024-04-04 |
CVE-2024-29748 |
Pixel privilege escalation |
| 2024-04-04 |
CVE-2024-29745 |
| 2024-06-13 |
CVE-2024-32896 |
| 2024-08-07 |
CVE-2024-36971 |
Kernel remote code execution |
| 2024-11-07 |
CVE-2024-43093 |
Framework privilege escalation |
| 2025-09-04 |
CVE-2025-48543 |
ART privilege escalation |
| 2025-12-02 |
CVE-2025-48633 |
Framework information disclosure |
| 2025-12-02 |
CVE-2025-48572 |
| 2026-06-02 |
CVE-2025-48595 |
Framework integer overflow |
The Pixel-specific rows do not apply to this hardware. CVE-2025-48543 does, because ART
is the runtime every Android 13 device executes.
The exposed components are shipped here
Checked in /vendor/lib64 on this device:
- Bluetooth: 9 libraries, including
android.hardware.bluetooth@1.0 and @1.1, plus
libbluetooth_audio_session
- Media and codecs: 28 libraries, including
libavcodec-58.so, which is FFmpeg
Lavc58.91.100, a 2019-era API with a long CVE history since
- Radio and RIL: 18 libraries, including
libimpl-ril.so
- Kernel:
unprivileged_bpf_disabled is 0
AppSupport runs Android apps natively through libhybris against these same vendor
libraries. A malicious APK is not isolated from them.
The chain
malicious APK (sideload, or an app store install)
-> ART LPE (CVE-2025-48543, no user interaction)
-> root inside AppSupport
-> vendor HAL and kernel surface (5.4 BSP, unpatched, bpf enabled)
-> host root
I am not claiming a working exploit was run on this device. The claim is narrower and it
is enough: the patch is absent, the affected version is in scope, the vulnerable code is
present, and the CVE is on the known-exploited list. That is what “vulnerable” means.
Why this is not a scheduling problem
current.
- There is no mainline path to route around it, since
ums9230 has no upstream DTS.
So the userspace moves and the substrate does not. The 956 CVEs are not late. They are
unreachable, and they stay that way for the rest of tye devices life.
