Base layer android?
I have confirmed on my end that certain media file types can be used to get root access via the residual android drivers and the missing cves.
My job here is done. Take care people.
Absolutely agree but op asked about that certain point iiuc - HAL and the underlying?
Care to provide me with some info via DM? To take a look at?
No, not right now. Ill run thru the cve list myself and see exactly what else there is.
So I got curious and ran a few checks myself.
Two things up front: I don’t own a C2, and checked it on a JP2 … so it says something about the structure, but not about the exact environment. And to be transparent, I used Claude Mythos 5.2 for a big part of the analysis.
The infos were probed from my JP2, so the results are not purely based on assumptions.
In short: the chain described in this thread doesn’t work like that, at least not on a JP2.
AppSupport reports its own security patch level (2026-05-05), which is different from the one on the host (2026-01-05). So running getprop on the host basically tells you nothing about the ART inside AppSupport. It also runs in a user namespace, so “root” inside the container is not root on the host.
And I couldn’t find a single root-owned Sailfish process that loads vendor libraries. The ones that do (lipstick, the app boosters, the browser, voicecall-ui) all run as defaultuser, and the HALs themselves run as their own users (mediacodec, radio, bluetooth and so on). So no “HAL bug = root”, and no 956 CVEs, at least on the JP2.
But to be fair, I was also kind of wrong. It’s, even if I weight in my strong simplification, more than the “small foundation” I described earlier that’s really getting used. There are quite a few native Android daemons running on the host (like mediaserver, keystore2, drmserver, etc.), plus some MediaTek logging daemons. SELinux is permissive, kernel.unprivileged_bpf_disabled is 0, and the root filesystem is a plain rw ext4 without verity. Only home is encrypted.
So I think the general worry is fair: the layers underneath lag behind, and they’re less locked down than on a stock Android. Most of us are happy to not live in a hermetically sealed environment where you’re not boss on your own device anymore. Would be interesting to hear from Jolla whether enforcing SELinux, restricting unprivileged BPF, and similar measures are realistic. Maybe there is a middle ground, to still give everyone the freedom they want, but at least have the default options sealing the system off enough to keep bad guys out.
Most of this is and was most probably already known by more versed users on the forum, but as said, my interest was piqued, and I wanted to dig a little deeper.
@djucjfbvvdjxnv if you really have a reproducible root via a media file, please send it to Jolla privately instead of posting it here. Without a file, a crash log or at least a CVE number, there’s nothing anyone can verify. And we don’t need to serve vulnerabilities on a silver platter for any script-kiddie that finds its way to this forum.
My point exactly. No worries. Thats the plan.
This is one of the weirder LLM-assisted FUD topics I’ve seen here in a while.
Yeah man, its crazy what a 2.50$ session will get you these days
IIRC, there’s just one port not relying entirely on Android blobs and binaries for its HAL. Everything accessible by software on the phone may be used for an exploit, whether it is directly used by the SFOS stack or not is not relevant. So yes, from a security perspective, SFOS is very much like an Android from the first days of porting.
I feel like I can share this safely as from what I can tell this is again nothing new.
In summery:
The Jolla C2 (Sailfish OS 5.2.0.22, Android rootfs droid-system-s19mps with SPL stuck at 2023-09-05) has SELinux enforcing off (enforce=0), with roughy 1054 CVEs in the 2023-10-2025-12 Android Secuirty Bulletin window - of which ~250 are reachable code, 49 kernel-context flaws (36 Mali GPU driver UAFs behind a world-writable /dev/mali0 plus 13 mainline af_unix/binder/dma-buf/eventpoll/mremap bugs), 36 Unisoc BSP CVEs (15 of them remote baseband/modem flaws, 8 video-decoder out-of-bounds writes reachable with “no aditional execution priviledges”, plus wifi/TeleService/camera/miscellanea), 102 AOSP rootfs entries (93 Bluetooth parsers behind bluebinder-to-vendor-HAL, ~15 critical RCE reachable from an adjecent radio with no interaction), 11 KEV exploited-in-the-wild CVEs (framework EoPs like CVE-2023-35674, CVE-2024-43093, CVE-2024-32896, CVE-2025-48572/48595, and Mali CVE-2023-4211/2024-4610), ~324 conditional flaws, and a 6-year-old FFmpeg 4.3.1 (2019) in the codec path - with the hardened findings being that 14 uid-0 root daemons expose abstract unix sockets acepting unprivileged connections, /dev/dri/card0, /dev/ion, /dev/sprd_ion and unpriviledged BPF are live from uid 100000, and defaultuser sits in the media, graphics, bluetooth, camera and input groups (so any session process can read the touchscreen/keyboad)
And thanks @pentti while the walls that do hold are: AppSupport is past the ART bug (SPL 2025-12-05), screen capture is gated by the sailjail D-Bus filter plus yama ptrace_scope=1, the bootloader is locked/AVB-enforcing, and the Mali ioctl layer is permission gated, which demotes the GPU driver bugs to second-stage targets - with the bottom line being that reachability is proven.
What remains is for me to comprehend the usability of this information, so if indeed there is anything new here, of which Im fairly certain : doubtful, please let me know.
Also for context: the entirety of this research cost me a bit over 3$ and about 2 days of my own time.
Was not the primary goal, my primary is to actually find a secure device, which is proving less likely the longer I dig into all the claims for all the devices.
IMO C2 is also not the best choice in manufacturing quality. Especially battery is a weak spot.
The Jolla C2 has been known to be vulnerable for years, so I’m not surprised.
This is the first im hearing that, I have people in red hat swearing by it. And articles about how eu governments are adopting its use for security.
I think thats my biggest dissapointment, that is just a rebrand like the trump phone.
And secondly, while nieche that it runs something like linux, im just super disappointed that there is no actually secure device that is worth any of my efforts.
Not even G.os really fulfills what I assume im looking for.
And until there is an open baseband, we won’t ever really get there.
The C2 was known to be that, and comes from a time where Jolla was happy to be able to put out something like … at all. If you’re looking for custom and modern hardware (thats also not already years old), the new Jolla Phone (2) ist worth a look. It’s designed and manufactured by Jolla themselves and came out this summer.
Jolla Phone 2026 is phone built by Jolla. So they have much bigger influence on low level parts of the OS then Reeder’s C2.
What’s the reason to not consider it?
Can’t find any mention of C2 to be marketed or hyped as such. Jolla. com says:
About C2 : https://jolla.com/content/uploads/2024/05/Jolla-Unveils-Mind2-AI-Computer-and-Community-Phone-and-Partnership-with-Reeder-May202024.pdf?x49828
The Jolla C2 is a reference phone built for the Sailfish OS community
About security devices : https://jolla.com/content/uploads/2026/10/CivSec-and-Jolla-Public-Safety-Market-Oct2026.pdf
A public safety phone is only as trustworthy as the software underneath it. For organizations in public safety, critical communications, national defense and total civil safety, the questions are no longer theoretical: who controls the operating system, where its updates come from, and what data leaves the device without the user knowing.
Your spending on LLM and your time is most welcome but could profit more JP2026 than C2.
Well maybe not this specific device but I do hear hype mentioning jolla as positioning for the sovereign option…but you’re probably right in that those statements are made unknowingly rather than people who are in the know.
Im hesitant to spend more money on this hobby especially since right now there’s no real way for me to know how good that actually is. Because again, if there’s no manufacturer support after purchase…we will eventually also end up with an ever longer growing exploit list as it will again support android. So its going to just be the same with extra steps.
