Yes, and everything works like it should.
Hi, I still can’t install new apps in Aurora.
I updated the F-Droid store, then updated Aurora to 4.2.2 (one week old).
I tried to clear cache and data; and restart the phone.
Nothing changed.
What could I do now?
Have you tried an Aurora Nightlies Build? Do you use the anonymous account?
Where are the nightly builds? I will stay anonymous.
Let me duckduckgo that for you. Uhm.
https://files.auroraoss.com/?folder=AuroraStore/Nightly
I gave up with the anonymous accounts, and just signed in with my account. What can go wrong?
Getting banned for ToS violation, losing access to the related gmail account?
I agree. And if that ever happens to anyone, one could just use another account. And so on.
I created a disposable account just for that purpose, so no problem if it gets banned.
Thanks, I just want to do the same steps. I installed aurora nightly, firefox via apk. If I open the desired new app via ‘Mit app öffnen’, it doesn’t install it. See pictures.
Hi Inte, thanks lot for your pictures. I had the correct configurations, it took me some time to discover, where to tap long to get the right menu!
For the others like me, here two pictures.
I really hope, that installing android apps (anonymous) over Aurora will get easier again, esp. for newbies (for many people this is important)!
I’m glad I could help. App search will probably never get as easy as it was again for anonymous accounts, since google appears to limit search queries per account.
I personally don’t mind the new search, though.
Small disadvantage: opening links in other apps, now I’m always asked, if I want to use Browser or Firefox ;-).
I don’t have an advanced option.
I don’t have a ‘open in external app’ option either.
ahh you have to do this trick now to search for apps.
That’s fine, but what if you log in with a google account?
Everything works as expected for me.
Hi, in the last week had several times the following problems with 4.2.2:
- open Aurora store → I can read for 1/2 second: “Requesting a new session”, then it disappears
- the store does not open after a long time
No improvement by: restarting Androidapp-Support, WIFI nor deleting cache from Aurorastore
By luck the following day it works again.
