Arabic diacritics showing not showing in popup keys
REPRODUCIBILITY (% or how often): 99%
BUILD ID = OS VERSION (Settings > About product): 3.4.0.24
HARDWARE (Jolla1, Tablet, XA2,…): XA2 Plus, X10
UI LANGUAGE: English
The Arabic diacritics do not show at all in the popup of a character key (accents in CharacterKey), in a custom keyboard layout.
However, these diacritics show correctly if they are inserted directly in the Caption or captionShifted of a CharacterKey.
Install an Arabic keyboard layout, such as Multi Keyboard Layouts
  1. Install Multi Keyboard Layouts
  2. Choose Arabic layout
  3. Press and hold the comma symbol
The diacritics should show in popup key
An empty field is shown instead, the diacritics aren’t rendered
Note that the diacritics are actually inserted when the accent key is pressed. They are rendered correctly by Sailfish on documents, bu not on the keyboard.
Note also that these diacritics are shown in the keyboard if written in the caption or captionshifted in the QML file.
Note also that sometimes, very rarely, the diacritics do appear on the popup, but it disappears again on reboot. I failed so far to reproduce the bug or how it appears.
Does anyone with knowledge of the keyboard in QT or Sailfish, or how rendering goes for the keyboard, have any clues or pointers to help me identify and reproduce this bug (and maybe fix if it’s not Sailfish core related) ?
Images to portray the bug :
The bug :
What it should show (very rarely, failed to reproduce) :
What the caption/captionshifted show correctly all the time :
Haven’t checked the Multi Keyboard Layouts package but as such this doesn’t sound like a bug in the Sailfish OS. That said, it could still be so that bug gets triggered due to a bug in the Sailfish OS side.
I found another related topic: Dead keys not working
@pherjung Reported that related topic internally as well.
Thanks @rainemak. The Arabic keyboard layout package by aline exhibits in some cases a similar issue.
I might suspect it’s related to fonts, or to how the text is drawn as diacritics are drawn in parts of the button.
Hi there, i just wanted to ask: is there now maybe a workaround to solve this problem with the missing arabic diacritics?
For what it’s worth, this Arabic keyboard works alright. The diacritics disappear when you move your finger over them, but they are visible otherwise.
…but they are visible otherwise…but not for me
The characters are invisible to me while pushing the comma sign, as shown in the screenshot above. However, I can hit them blindly if I guess their approximate location correctly. But i often need more attempts, to find them correctly
Oh - i have to correct myself: i now tried out again pushing the comma by holding it and moving the finger - and surprisingly the diacritics appear while
letting the finger pushed! Maybe it is because a few days ago i installed the multi keyboard layout beneath the one you mentioned ? But i didn’t recognized any change in the behaviour of the keyboard, so i deinstalled multi keyboard layout again.
But now mystically they shown up! I am a little bit confused but it’s ok. With this kind of behaviour i can live
ezgif.com-crop
Btw.: the gif isn’t animated within the phone’s Forum- application but in (desktop-)browser it works!
Awesome. What is the screenshot application you’re using on SFOS to take these?
Huh, that’s strange! I’m using a C2, and they show up fine for me, with exactly the opposite behaviour to your GIF. Which device are you using?
One thing I am noticing is that the pop-up is spread across two rows in my cases, but I doubt that matters.
I connected my Phone via Screencast with my Computer and then i captured a scrennvideo and made a gif out of it
I also have a nice to have C2
Hi, the disappearing diacritics seems to be a bug on how SFOS handles them, and happens occasionally.
I can’t reliably reproduce it as on some phones and OS versions they appear fine, and on others not.
