Hi Andrew,
I tested with Xperia 10 II pairing to Garmin Edge navigator and running Garmin Connect which is working fine!
Cheers,
Nek
Hi Andrew,
Cheers,
Nek
Same phone and same watch but when the Withings app asks to turn on bluetooth, nothing happens.
I turned on bluetooth (Sailfish OS) before trying to pair the phone and watch.
OP said devices an be paired with AppSupport but I never managed to find where/how.
As you show it clearly works for you, I’d like to make it work for me as well, and finally move from my Android phone to my Sailfish phone.
Have you enabled early access updates, updated to 5.1.0.8 Pispala and installed AppSupport Bluetooth (beta) from the Jolla store?
Nope, I’m still new to Sailfish.
Tampella 5.0.0.78 freshly updated.
How to enable early access updates ?
It’s a setting on https://account.jolla.com/.
A small disclaimer, though. Early access releases are, by definition, not yet ready for general use. So you should expect bugs and other issues. If you are still new to Sailfish OS, I would recommend waiting until the final release becomes available.
Thanks, I proceeded as you said and it’s finally working.
I’ll be able to phase out my Android phone.
Did anyone try popular smartwatches like Samsung, garmin, Fitbit etc? Some of them write data in health apps that I assume requires background services and permissions.
Yep. My Garmin Forerunner 255 syncs fine with Garmin Connect.
Could you share mi fitness app version?
I bought today a cheap Denver (SWC-176) smartwatch for 10€ from K-citymarket as it was on sale just for fun to test how it would work (also wanted a cheap backup smartwatch). And it work great compare to the Huawei Watch GT 2 (ETC) that had “few issues”
if anyone in Finland is interested, there was also a nice powerbank for 10€
Version 9.3.962. Downloaded from apkmirror
Could we also switch the audio sink to AppSupport Bluetooth devices?
It’s so cool. I just connected successfully my MTB helmet Sena M1 EVO with my C2. It has so clear sound. And the helmet battery after 2 years chargimg was still on high level. Thank you @jolla. It’s so amazing. ![]()
I finally got my EV charger (TeltoCharge) paired with my Xperia 10 III. It took a million tries and was really frustrating as the charger locks itself after three failed attempts and has to be restarted. I don’t know what was the trick but finally pairing succeeded and now it works fine.
Hioki CM4731 multimeter connected to the Gennect app via BLE immediately.
JK-BMS software (ble) works
Goodwe Solargo invertor control sw works (bt)
PHEV Watchdog with ELM327 type OBDII bluetooth adaptor works.
I didn’t test any app but what about devices that don’t support pairing like the Switchbot Thermo-Hygrometer.
It simply answers a scan with battery readings in service_data and temperature and humidity in manufacturer_data, e.g.
[nemo@xperia ~]$ bluetoothctl
[bluetoothctl]> scan le
[CHG] Device C9:34:30:37:75:59 ManufacturerData.Key: 0x0969 (2409)
[CHG] Device C9:34:30:37:75:59 ManufacturerData.Value:c9 34 30 37 75 59 e4 02 07 94 3f 00 .407uY…?.
[bluetoothctl]> scan off
Are there more such devices around?
I am very happy to report that it seems that Oura is working just fine
I did the connetion through the app, which worked without any problem
The new beta AppSupport Bluetooth has been downloaded, and I can use https://www.skyrc.com/mc5000 with the app https://play.google.com/store/apps/details?id=com.skyrc.q200.
Thank you.
