Android AppSupport broken with upgrade to SFOS 5.0.0.72
REPRODUCIBILITY: always
OS VERSION:5.0.0.72
HARDWARE: Xperia 10 III
UI LANGUAGE: English
REGRESSION: yes
Prior to upgrade to 5.0.0.72, Android AppSupport worked. I don’t recall the prior OS version. After upgrade Android AppSupport will initially load, and function, then after a while will fail. Once AAS fails it will not restart. Viewing the AAS config page shows the status as “unable to start”. Trying to start AAS then takes it inot an infinite loop of trying to start and failing.
AAS is not set to start on bootup.
After a fresh reboot AAS can be started through the config page, or started through launching an Android app, eg VLC. If no Android app is started AAS continues to run. If an Android app is started AAS will fail after a short period of time.
  1. Restart phone
  2. Launch Android app (and thus AAS)
  3. Use Android app. After a while AAS will fail and Android app will stop functioning.
Android app and AAS will continue working indefinitely.
Specific Android app (and other Android apps will fail to run)
duplicate of https://forum.sailfishos.org/t/xa2-i-often-lose-android-app-support-during-standby/25678?
Ah, OK. I hadn’t seen that because different hardware.
