As asked here on TJC
and here as well
This tiny little patch
— /root/rpmbuild/SOURCES/vpnc-0.5.3/vpnc.c.orig+++ /root/rpmbuild/SOURCES/vpnc-0.5.3/vpnc.c@@ -93,7 +93,11 @@0x90, 0xCB, 0x80, 0x91, 0x3E, 0xBB, 0x69, 0x6E,0x08, 0x63, 0x81, 0xB5, 0xEC, 0x42, 0x7B, 0x1F};-const unsigned char VID_NATT_RFC = { /* “RFC 3947” /+const unsigned char VID_NATT_03[] = { / “draft-ietf-ipsec-nat-t-ike-03” /+ 0x7d, 0x94, 0x19, 0xa6, 0x53, 0x10, 0xca, 0x6f,+ 0x2c, 0x17, 0x9d, 0x92, 0x15, 0x52, 0x9d, 0x56+};+const unsigned char VID_NATT_RFC[] = { / “RFC 3947” */0x4A, 0x13, 0x1C, 0x81, 0x07, 0x03, 0x58, 0x45,0x5C, 0x57, 0x28, 0xF2, 0x0E, 0x95, 0x45, 0x2F};@@ -146,6 +150,7 @@{ VID_NATT_01, sizeof(VID_NATT_01), “Nat-T 01” },{ VID_NATT_02, sizeof(VID_NATT_02), “Nat-T 02” },{ VID_NATT_02N, sizeof(VID_NATT_02N), “Nat-T 02N” },+ { VID_NATT_03, sizeof(VID_NATT_03), “Nat-T 03” },{ VID_NATT_RFC, sizeof(VID_NATT_RFC), “Nat-T RFC” },{ VID_DWR, sizeof(VID_DWR), “Delete With Reason” },{ VID_CISCO_FRAG, sizeof(VID_CISCO_FRAG), “Cisco Fragmentation” },@@ -1086,7 +1092,8 @@a->af = isakmp_attr_lots;a->u.lots.length = 4;a->u.lots.data = xallocc(a->u.lots.length);- *((uint32_t ) a->u.lots.data) = htonl(2147483);+ //((uint32_t *) a->u.lots.data) = htonl(2147483);+ *((uint32_t *) a->u.lots.data) = htonl(3600);a = new_isakmp_attribute_16(IKE_ATTRIB_LIFE_TYPE, IKE_LIFE_TYPE_SECONDS, a);a = new_isakmp_attribute_16(IKE_ATTRIB_AUTH_METHOD, auth, a);a = new_isakmp_attribute_16(IKE_ATTRIB_GROUP_DESC, dh_group, a);@@ -1272,6 +1279,8 @@l = l->next = new_isakmp_data_payload(ISAKMP_PAYLOAD_VID,VID_NATT_RFC, sizeof(VID_NATT_RFC));l = l->next = new_isakmp_data_payload(ISAKMP_PAYLOAD_VID,+ VID_NATT_03, sizeof(VID_NATT_03));+ l = l->next = new_isakmp_data_payload(ISAKMP_PAYLOAD_VID,VID_NATT_02N, sizeof(VID_NATT_02N));@@ -1497,6 +1506,12 @@seen_natt_vid = 1;if (natt_draft < 1) natt_draft = 2;DEBUG(2, printf(“peer is NAT-T capable (RFC3947)\n”));+ } else if (rp->u.vid.length == sizeof(VID_NATT_03)+ && memcmp(rp->u.vid.data, VID_NATT_03,+ sizeof(VID_NATT_03)) == 0) {+ seen_natt_vid = 1;+ if (natt_draft < 1) natt_draft = 2;+ DEBUG(2, printf(“peer is NAT-T capable (draft-03)\n”));} else if (rp->u.vid.length == sizeof(VID_NATT_02N)&& memcmp(rp->u.vid.data, VID_NATT_02N,sizeof(VID_NATT_02N)) == 0) {@@ -2498,7 +2513,8 @@a->af = isakmp_attr_lots;a->u.lots.length = 4;a->u.lots.data = xallocc(a->u.lots.length);- *((uint32_t ) a->u.lots.data) = htonl(2147483);+ //((uint32_t *) a->u.lots.data) = htonl(2147483);+ *((uint32_t *) a->u.lots.data) = htonl(3600);a = new_isakmp_attribute_16(ISAKMP_IPSEC_ATTRIB_SA_LIFE_TYPE, IPSEC_LIFE_SECONDS, a);if (dh_group)
would fix that.
For now you would need to check version of vpnc (SFOS3.2 ~ 0.5.3) and download sources, apply patch, compile and install to /usr/sbin to allow configuring and using with GUI. Or install some nokius provided package from sailfishmods.de.
Would you please consider?
