Yes, VPN to a Fritzbox would be possible now.
Unfortunately, Xperia X10 III is still unable to establish IPV4 mobile network connection with major carriers, so no VPN from mobile network, only from WiFi.
Wireguard VPN to Fritzbox had been working fine, but is broken since SFOS 4.5.
Maybe Jolla have fixed this bug but the situation is worse than before. Bummer.
Jey, eventually!
Um was geht’s in dem Artikel? Heise erzwingt leider tracking.
7.5 is available for the 5530 now too.
I’m using Firefox focus to avoid tracking, or at least reduce it. Are there any websides at all that still do not track?
I eventually updated my fibre fritzbox (5530) and I’vejust configured wireguard vpn from my xperia 10ii to the fritzbox now - I simply enabled wireguard in the fritzbox web interface and downloaded the settings file.
My first attempt to load this file in the jolla settings failed since it containes a double dns entry (fritzbox local ip and, for some unknown reason, ‘fritz.box’).
I simply deleted the second entry and the settings file was accepted by SfOS instantly. Wireguard VPN seems to work fine now, but I haven’t tested for longer than 5 minutes yet.
