They actually said that they
which to me sounds too vague to rely on, as “aim” sounds more like an intention than any solid timeframe, and such “further testing” may turn into months or quarters, as it already happened in the past.
Nevermind, I don’t want to start any debate on this, I just can’t comprehend why they are so unwilling to make such small and friendly gestures to their faithful customers like extending the voucher expiry date so that one could make a fully conscious and risk-free choice a month or two later, being fully aware of if either the echo issue can be fixed on the X10 III or if/when VoLTE will come to the X10 II.
Recently I salvaged two phones by installing Lineage OS 18.1 on them and giving the phones to two of my relatives (one of them being my mother whose previous phone just broke). Both those phones have the echo issue, but each of them in a different way. One has the echo only in speakerphone mode (but the echo is totally unbearable, the caller just can’t stand it, mostly hearing himself, so the speakerphone mode is totally unusable but the normal mode is fully OK), and the other one has the echo problem while normally using the earpiece, and it is slightly less troublesome. None of those phones had any echo issues with their original stock Android firmwares, it is Lineage OS (i.e. AOSP) what introduced that problem. On the XDA forums, I’ve seen that there are some attempts to cancel the echo in those ROMs, but it’s mainly some tricks with side effects, like modifying the overall volume or mic sensitivity, or something like that.
Anyway, while such an issue is kind of bearable on old salvaged phones having been given new life with Lineage OS and provided to some elderly people whose expectations from a smartphone are quite basic, if the echo cancellation issue on the to be newly bought €400+ X10 III is anywhere near that of Lineage OS, for me it is a deal breaker.
Hence, I would really like to be given possibility of making a conscious choice, knowing if either the echo is fixable on the X10 III or if/when VoLTE will come to the X10 II.
So please Jolla, kindly extend my voucher’s expiration date by the time you are able to provide this basic information.
) which it never did on the XA2 to the extent it was usable in everyday life. I don’t do patches and I haven’t enabled VoLTE whilst its still in Beta - I try and keep things as stock as possible to minimise issues. The only new (for me) annoying issue I’ve found so far is apps being killed whilst in use. This is mainly the web browser (regularly) but does affect other apps (irregularly) as well - this never happened to me on the XA2. It still suffers from some of the long standing bugs seemingly affecting all SFOS phones (e.g. Android apps losing network connectivity, email sync failures, cloud services (Dropbox, Onedrive) not working, etc, etc), but overall I’m pleased I did upgrade to the X10 III. It’s the closest implementation so far towards being acceptable as a daily driver for me.
