A few questions regarding GPS
regarding GPS i made the following test on 3 phones together
i ran these tests a few tens times each
all of them in GPS only mode
XA2 Ultra with SfOS 5.0.0.68, GPSInfo + OSM Scout
time to first fix: very erratic, from almost immediate to more than one hour
battery drainage: usually very high average over 10%/hour
another strange fact
very often when i take a train GPS will locate me at the Paris station 300 km away
FairPhone 2 with SfOS 3.0.0.8, GPSInfo + OSM Scout
time to first fix: usually almost immediate
battery drainage: usually less than 1%/hour
Huawei MYA-L11 with Android 6 SatStat + OSMAnd~
time to first fix: usually a few minutes
battery drainage: usually much less than 1%/hour
what is wrong?
It has been discussed quite a few times in this forum that the XA/XA2 series are problematic wrt. GPS reception.
Regarding GPS on Jolla C2 with SfOS 5.0.0.68, GPSInfo + Magic Earth:
time to view >=3 satellites: usually almost immediate
Also Magic Earth positioning is often very unstable while driving, even when 7 GPS satellites are in use (that should provide good accuracy of around 4 meters): how is it possible ?
Time to first fix on my XA2 (non-Ultra) is also often quite fast, but sometimes takes 20 minutes or so.
Are you using the Mozilla location packages? Maybe that station is where SNCF say the IP address you got from the onboard WiFi. Anecdotally, I have observed worse GPS performance when using the Mozilla packages - it seems that when I get a coarse fix quickly I can wait “forever” for it to improve.
At least some of us have lots of trouble with GPS on the C2, see this thread:
Symptoms include generally “noisy” GPS position and sudden jumps, that can be hundreds of meters. I have even seen position jump maybe 400 m followed by smooth tracking that was parallel to my path and off by 400 meters!
@jojomen
not as far i know, i never installed it, but maybe it got installed by some app?
how do i know if it is installed and used ?
my settings are GPS Only
@nephros
i know that and have read these threads which did not help very much
i have a dream:
somebody from jolla gives a statement about that!!!
XA2 have hardware problems regarding GPS.
These issues are not so visible in android or other OSes because of other techniques used to help determining position.
Iirc, (but not sure, might be found in the two major old GPS threads) this was acknowledged by someone of Jolla, once, but where?
Anyway, I fixed my XA2 GPS issue again (needed when it has shocks/too much dirt/over some time…) by opening it and it now works again.
Here is a tutorial:
I am so sure that statement is a perfect motivation to spare you the extra time of searching the forum for any Jolla employee on a Friday afternoon.
Hint: check last community meeting ;).
@WT.Sane
you may be right
next time i will ask my question on a monday morning :grinning_face_with_smiling_eyes:
