[5_2_0_16] [JP2026] Earphone volume adjustment does not work
REPRODUCIBILITY:
OS VERSION: 5.2.2
HARDWARE: Jolla Phone 2026
UI LANGUAGE: Suomi
REGRESSION:
Earphone volume adjustment does not work when on normal GSM phone call.
Volume slider moves on the UI, but the volume stays the same
Make a call or receive a call
  1. Make a call or receive a call
  2. Try to adjust the volume from hardware buttons
  3. Nothing happens
Earphone volume stays the same
I also have the same issue with the earphone and the loudspeaker during calls (in contrast in music the loudspeaker works perfectly)
I think this bug warrants a bit of clarification and analysis to get to the bottom of how it works.
For example, without actually testing the sound level – just looking at it visually – I can adjust the volume whilst an app is open (I’ve tried this with the default browser and Firefox), but when I’m on one of the home screens, the volume remains locked; pressing the buttons displays the volume control bar without changing the volume level.
However, the overall volume can be adjusted quite easily via the ‘Settings – Sound’ menu, and if you return to the home screen, you can see that the volume level has changed, yet it’s still impossible to adjust it using the buttons…
I don’t get the impression that this is limited solely to calls.
I’ve taken the liberty of changing the subject line. I hope you don’t mind.
However, would it be possible for you to update the OS version in your report please ?
Updated today, let’s see how it works tomorrow when I start receiven phone calls :grinning_face_with_smiling_eyes:
It works for me! I hope it’s the same for all of you! :blush: I can finally adjust the volume from the home screen!!
It helped little bit, but still too loud with lowest setting!
Hi, I’m experiencing this problem on my Xperia 10 III running 5.1.0.11. It’s a bit of a bad situation, and I hope it can be fixed for those phones as well. I have Apple EarPods and a pair of Sony headphones—I don’t know the exact Sony model—but with both of them, I just can’t adjust the volume properly, exactly like in the report.
I have this bug on my JP2026 5.2.0.17 and the volume is so loud I don’t even have to set it to speaker. Volume only goes down when you come to the end and you mute.
