REPRODUCIBILITY:
OS VERSION: 4.6.0.13
HARDWARE: Sony Xperia XA2 Ultra
UI LANGUAGE: English
REGRESSION:
Android AppSupport stops, crashing all open Android apps, after any kind of input within an open Android app after upgrade to Sauna 4.6.0.13. Andorid AppSupport Security patch level is 05/12/2023.
While the upgrade process itself ran smoothly, after the upgrade Android apps can no longer be used as any attempt to operate the app, be it scrolling, selecting, text input, etc., will cause Android AppSupport to crash. This behavior is inconsistant, as some input will be tolerated, while any further touch of the screen will then crash AppSupport.
Has anyone encountered similar issues after upgrade?
PRECONDITIONS: Android App Support must be running.
Open Android app
Try to scroll on page or reply to a message (e.g. in Signal app)
App should stay open and execute command
App crashes after AppSupport shuts down, restarting immediately
Thanks for your reply. Update went well, no issues there. And no, no google services installed. If I don’t touch an open Android app, it’ll just sit there. As soon as I try to scroll though, it’ll crash.
Maybe uninstalling and reinstalling Android Support might help. But this is just an idea.
You might want to backup some Android data before doing so, start with one app and successively reinstall backups and other apps.
Hi WT.Sane,
thanks for your suggestion to reinstall AppSupport. I had totally forgotten that it is not an integrated module of the OS. Unfortunately, reinstalling didn’t help, but on the other hand, my data stayed intact, so no need to reconfigure the Android apps on my phone.
It is beginning to dawn on me that resetting the device might be the only option, though, but I’m still pretty hesitant. Maybe someone will come up with a brilliant fix , so I’ll just wait a little longer and try my luck with exercising some patience.
Are shults and me the only two on the planet experiencing this frustrating issue?
How much free space do you have in the root partition / overall?
As a last resort before reflashing the phone, you could try to delete Android App Support the brutal way (if you didn’t already), as described in the documentation:
I tried freeing up as much space as I could. Here’s the result. I’ll try deleting app support the hard way once I’m back home from my class trip. Don’t want to fiddle too much as long as I need the phone here. I do appreciate your assistance very much. Thanks, I’ll let you know how it worked out.
Good morning everyone,
I have the same problem too…
I did a total flash of Sauna just yesterday, on an Xperia 10 II dual sim.
In particular, I notice that WhatsApp crashes and Nextcloud Notes doesn’t keep the note I’m viewing open if I close the screen.
I have microG installed, I just removed it, let’s see if the situation improves…
Hello everybody,
I have the same issue on my X10 dual sim. All Android Apps can be started but crash after any action within it. The app support seems to be restarted immediately.
I have microG installed and around 600 MB free space on System data about 25 GB on User data.
I also have this problem, or very similar, (as I have mentioned in another thread) although it is much worse on my Xperia 10 iii than it is on my XA2 Plus. sometimes you have to try and start an Android app 5 or 6 times before it will open and work successfully.
I have a similar problem on my xa2 plus, I did a reinstall due to the increase in memory, but sometimes when opening an application the App support message appears starting, before it happened only with here maps or google maps now it happens very frequently with any application
We would appreciate getting some logs from the phones having problems reported in this thread.
Use the phone. As soon as you have seen the problem occur, run the following commands.
Please mention the date and time when this happened to make it easier to read the logs.
Thanks everyone for your support. Unfortunately, I haven’t succeeded generating log-entries. Is there anyone more tech-savvy out there with the same issue who could post a log after AppSupport crashes on their phone?
I also have a similar problem. Since the update to “Sauna”, the last functioning banking app also crashes. As soon as I enter my PIN in the ING app, the program crashes.
I actually wanted to release another device for the move to another system. Now I have to wait for a release pin by post. Although I’ve been using Sailfish since Jolla 1, it just confirms to me that there’s no future in this. All the important functions that you unfortunately have to rely on today via smartphone don’t work.
07-04 00:29:45.046 2616 2654 D GeckoIdleService: Get idle time: time since reset 13 msec
07-04 00:29:45.046 2616 2654 D GeckoIdleService: Idle timer callback: current idle time 13 msec
07-04 00:29:45.046 2616 2654 D GeckoIdleService: next timeout 4987 msec from now
07-04 00:29:45.046 2616 2654 D GeckoIdleService: SetTimerExpiryIfBefore: next timeout 4987 msec from now
07-04 00:29:45.046 2616 2654 D GeckoIdleService: reset timer expiry to 4997 msec from now
07-04 00:29:46.027 260 260 E Zygote : System zygote died with exception
07-04 00:29:46.027 260 260 E Zygote : java.lang.IllegalArgumentException: event time must not be in the future
07-04 00:29:46.027 260 260 E Zygote : at com.android.server.power.PowerManagerService$BinderService.userActivity(PowerManagerService.java:4976)
07-04 00:29:46.027 260 260 E Zygote : at android.os.PowerManager.userActivity(PowerManager.java:1190)
07-04 00:29:46.027 260 260 E Zygote : at android.os.PowerManager.userActivity(PowerManager.java:1155)
07-04 00:29:46.027 260 260 E Zygote : at com.android.server.accessibility.AccessibilityInputFilter.handleMotionEvent(AccessibilityInputFilter.java:315)
07-04 00:29:46.027 260 260 E Zygote : at com.android.server.accessibility.AccessibilityInputFilter.processMotionEvent(AccessibilityInputFilter.java:297)
07-04 00:29:46.027 260 260 E Zygote : at com.android.server.accessibility.AccessibilityInputFilter.onInputEvent(AccessibilityInputFilter.java:237)
07-04 00:29:46.027 260 260 E Zygote : at android.view.InputFilter$H.handleMessage(InputFilter.java:249)
07-04 00:29:46.027 260 260 E Zygote : at android.os.Handler.dispatchMessage(Handler.java:106)
07-04 00:29:46.027 260 260 E Zygote : at android.os.Looper.loop(Looper.java:223)
07-04 00:29:46.027 260 260 E Zygote : at com.android.server.SystemServer.run(SystemServer.java:652)
07-04 00:29:46.027 260 260 E Zygote : at com.android.server.SystemServer.main(SystemServer.java:434)
07-04 00:29:46.027 260 260 E Zygote : at java.lang.reflect.Method.invoke(Native Method)
07-04 00:29:46.027 260 260 E Zygote : at com.android.internal.os.RuntimeInit$MethodAndArgsCaller.run(RuntimeInit.java:599)
07-04 00:29:46.027 260 260 E Zygote : at com.android.internal.os.ZygoteInit.main(ZygoteInit.java:925)
07-04 00:29:46.027 260 260 D AndroidRuntime: Shutting down VM
07-04 00:29:46.029 260 260 E AndroidRuntime: *** FATAL EXCEPTION IN SYSTEM PROCESS: main
