[4.6.0.13] Android AppSupport crashes at any activity after upgrade to Sauna
This seems to be a recurring theme:
WLAlienEventDevice: WLAlienEventTouch::checkOffset time offset diverged by more than 100 millisecond (4294888701 ns), resetting offset to 2329793188515
4294888701 looks suspiciously close to UINT_MAX, maybe this is an integer underflow issue?
07-04 01:15:11.272   261   276 W WLAlienEventDevice: WLAlienEventTouch::checkOffset time offset diverged by more than 100 millisecond (4294888701 ns), resetting offset to 2329793188515
07-04 01:15:11.708   261   361 E WificondScannerImpl: Timed out waiting for scan result from wificond
07-04 01:15:13.523  1603  1755 I OkHttpWebSocketConnection: [normal:8157010] Sending keep alive...
07-04 01:15:13.524  1603  1755 I OkHttpWebSocketConnection: [unidentified:149135018] Sending keep alive...
07-04 01:15:13.527  1603  1755 D AlarmSleepTimer: Setting an exact alarm to wake up in 19999ms.
07-04 01:15:13.527  1603  1603 W AlarmSleepTimer: Waking up.
07-04 01:15:14.217  2803  2842 D GeckoIdleService: Get idle time: time since reset 3 msec
07-04 01:15:14.218  2803  2842 D GeckoIdleService: Idle timer callback: current idle time 3 msec
07-04 01:15:14.218  2803  2842 D GeckoIdleService: next timeout 4996 msec from now
07-04 01:15:14.218  2803  2842 D GeckoIdleService: SetTimerExpiryIfBefore: next timeout 4996 msec from now
07-04 01:15:14.218  2803  2842 D GeckoIdleService: reset timer expiry to 5006 msec from now
07-04 01:15:15.571   261   276 W WLAlienEventDevice: WLAlienEventTouch::checkOffset time offset diverged by more than 100 millisecond (4295483753 ns), resetting offset to 2334088672268
07-04 01:15:15.797   261   261 E Zygote  : System zygote died with exception
07-04 01:15:15.797   261   261 E Zygote  : java.lang.IllegalArgumentException: event time must not be in the future
07-04 01:15:15.797   261   261 E Zygote  :      at com.android.server.power.PowerManagerService$BinderService.userActivity(PowerManagerService.java:4976)
07-04 01:15:15.797   261   261 E Zygote  :      at android.os.PowerManager.userActivity(PowerManager.java:1190)
07-04 01:15:15.797   261   261 E Zygote  :      at android.os.PowerManager.userActivity(PowerManager.java:1155)
07-04 01:15:15.797   261   261 E Zygote  :      at com.android.server.accessibility.AccessibilityInputFilter.handleMotionEvent(AccessibilityInputFilter.java:315)
07-04 01:15:15.797   261   261 E Zygote  :      at com.android.server.accessibility.AccessibilityInputFilter.processMotionEvent(AccessibilityInputFilter.java:297)
07-04 01:15:15.797   261   261 E Zygote  :      at com.android.server.accessibility.AccessibilityInputFilter.onInputEvent(AccessibilityInputFilter.java:237)
07-04 01:15:15.797   261   261 E Zygote  :      at android.view.InputFilter$H.handleMessage(InputFilter.java:249)
07-04 01:15:15.797   261   261 E Zygote  :      at android.os.Handler.dispatchMessage(Handler.java:106)
07-04 01:15:15.797   261   261 E Zygote  :      at android.os.Looper.loop(Looper.java:223)
07-04 01:15:15.797   261   261 E Zygote  :      at com.android.server.SystemServer.run(SystemServer.java:652)
07-04 01:15:15.797   261   261 E Zygote  :      at com.android.server.SystemServer.main(SystemServer.java:434)
07-04 01:15:15.797   261   261 E Zygote  :      at java.lang.reflect.Method.invoke(Native Method)
07-04 01:15:15.797   261   261 E Zygote  :      at com.android.internal.os.RuntimeInit$MethodAndArgsCaller.run(RuntimeInit.java:599)
07-04 01:15:15.797   261   261 E Zygote  :      at com.android.internal.os.ZygoteInit.main(ZygoteInit.java:925)
07-04 01:15:15.798   261   261 D AndroidRuntime: Shutting down VM
07-04 01:15:15.798   261   261 E AndroidRuntime: *** FATAL EXCEPTION IN SYSTEM PROCESS: main
I’m testing with firefox, that’s why you see gecko-related logs. Interacting with any android app for <15s is enough to reproduce this.
Any news about this? I can’t really use my phone after upgrading to 4.6
EDIT: Discourse says that I can’t post any more replies to this topic, so editing this one.
Hey @jonico, thanks for your reply.
I found android settings – I need to tap ā€œAndroid version 11ā€ in Settings > Android AppSupport 5 times to launch it. But I can’t figure out how I’m supposed to ā€œselect the windows form factorā€. It’s nice that it’s a 30 sec trick but it’s a challenge to keep the settings app up for 30 secs. Any way to update this setting via the command line?
You need to enter in android settings, to select the windows form factor. A 30 secs trick, and all will be fine :wink:
I experience the same with ice cream. Since licorice ice cream disappeared from Berlin there’s literally no use in cows or buildings anymore.
If I remember good: These are the settings to enable
Sorry, that doesn’t help. Took two days of trials for us to activate those two, but that didn’t help at all. Keeps crashing after a few taps.
Seems like a dead end here, doesn’t it? Has anybody tried a device reset? Honestly, I’m quite hesitant to give it try, dreading all the hassle that comes with it.
Is there any news from Jolla updating Android AppSupport?
Cheers!
Just wondering whether the Sauna release note that ā€œScrolling in Firefox (and in some other apps relying on timestamps) is smootherā€ might bear any solution to our issue.
The error message is quite clear, we need advice from the sailfish team to proceed.
Right, then let’s hope they find the time to fix it.
Please, do not touch/change the Android settings. Doing so could cause unexpected phenomena.
Let AppSupport do its job.
In the APPS section of the Android settings, only one item,
ā€œForce activities to be resizeableā€,
should be enabled.This is the default after flashing Sailfish and installing AppSupport.
A new revision of this document is available now.
A couple of problems were observed with the removal of AppSupport on 4.6.0.
This issue popped up last week for me. Any Android App crashes shortly after launch.
The update to Sauna went fine (worked fine for a week). This issue started the moment after I’ve updated a few apps with the Aurora Store as I always do. Right after the update no android app works anymore.
Xperia 10 III, MicroG
I have uninstalled Android AppSupport from the Jolla Store. I have not rebooted or done anything else after this. So far my apps stopped crashing.
The question is in what kind of state am I?
I did not reinstall Android AppSupport and on the store it says I can install it.
You say your apps stopped crashing, but how can you run Android apps without AppSupport? Or do your Jolla apps crash too, like I have observed my Sailfish browser do on several occasions?
That is what I do not know. The phone rebooted in my pocket and AppSupport was gone.
Reinstalled > Apps are crashing again. Cannot reproduce my earlier state by uninstalling AppSupport :frowning:
I wonder if anyone at Jolla is listening here.
It’s so tragic, when I come to think of it. Next week, when our summer holidays end and our new school year begins, I’ll be needing my Android apps, so I had no choice but to order a Samsung Galaxy S9+ to install /e/OS on it in order to have a fully functioning phone. That’s me saying goodbye to Sailfish, I guess. Pity!
Any news on the issue? Also waiting for a solution
There is a fix for the crashing Android apps in the upcoming 4.6.0 release. It will probably not prevent the crashes of all apps but hopefully most of them.
For example, I have the ING Banking app, and opening it from the app grid works fine. I have no account so I cannot properly test the app, however, it stays up at the ā€œLet’s get startedā€ view and in the next couple of pages.
