REPRODUCIBILITY: 100
OS VERSION: 4.5.0.19
HARDWARE: Pine64 PinePhone (OG)
UI LANGUAGE: EN-US
REGRESSION: Same issue for a couple releases
When using the audio recorder, or calling someone the audio coming out is extremely quiet and garbled, yelling into the microphone yields some results where it is barely able to be heard (you have to put your ear on the speaker to hear a faint noise.
Install the latest build, and try calling or recording audio and playing it.
- Press record and talk into the microphone
- Save the recording and play it
You should hear some distinguishable noise of you talking
Yelling into the microphone yields some results where it is barely able to be heard (you have to put your ear on the speaker to hear a faint noise.
Updated using zypper refresh && zypper update
as the audio output is broken on the current images, so an update was required.
N/A
