[4.5.0.16] predictive text input broken
REPRODUCIBILITY: unsure
OS VERSION: 4.5.0.16/4.5.018 (licensed version)
HARDWARE: Xperia Xa2
UI LANGUAGE: English US
REGRESSION: predictive text input fails
When typing on the keyboard no “word suggestion” is provided. The clipboard icon appears, the rest of the line is empty.
During upgrade I was recommended to remove a few packages related to predictive text input (not sure of their exact names). I uninstalled them using pkcon remove. The upgrade went well but after reboot I had lost predictive text input.
After refreshing the package list (pkcon refresh) I tried to install it Jolla store but it simply says “waiting” to end up with an error.
Predictive text input worked well before upgrade.
  1. system upgrade to 4.5.0.16 (upgrade to 18 did not fix or change anything)
Working predictive text input, ie word suggestion as you type or Chinese characters displayed as Pinyin is input.
empty row at the top of the keyboard (only the clipboard icon shows up)
No change applied, simply followed to recommendation to uninstall xt9 related packages.
Among the other things i tried:
  • enable/disable different languages
  • uninstall/reinstall jolla-keyboard-layout-chinese package
  • restart maliit-server
  • reboot
Ever since the upgrade to 4.5.0.19 prediction stops working until a reboot several times a day on my X10II.
Just to provide some context into the severity of this issue: predictions are the only input method for a number of languages. Please fix this ASAP.
