I was transferring a backup from X10II to X10III via NextCloud. The backup worked - the .tar.gz file appeared in the could - but restore couldn’t find the file.
Nextcloud to save backup to. Memory card backup/restore untested.
Make a backup to cloud
Make sure the file is there
Log in to the Nextcloud account on the new phone
Try to restore the backup
The backup is found and is restored
The backup isn’t listed and can’t be restored
No modifications (yet).
Copying the backup from the cloud to the memory card didn’t make it appear. The previous backup was a .tar file, and the new one a .tar.gz. Renaming the backup file from .tar.gz to .tar made it appear, and the backup succeeded. (Using file to determine the file type, it was a .tar archive, not a gzipped file.)
I first had the same problem with backup from Dropbox, but when I checked Dropbox in desktop browser, I found that Sailfish backup program saved backup in different folders from each hardware unit. So I just moved backup file from Xperia X folder to Xperia 10 lll folder, and restore worked just fine.
Yes, this worked for me.
One extra step I did was to first create a backup with the new device so as to create a directory in the cloud, and then copy the old backup into that directory.
