BUILD ID = OS VERSION (Settings > About product): 4.4.0.58
HARDWARE (XA2, X10, X10 II, …): XA2+
UI LANGUAGE: ru
in release notes we have “Bluetooth Secure Simple Pairing via NFC enabled and deployed”, but in my case it not work
remove paired before hedphones from bluetooth devices
press power on hedphones while it power on and keep pressed while it enable pairing mode
enable NFC
try pair with NFC (phone is vibrated)
headphones should automatically pair
nothing happens
i was try do not use pairing mode on headphones too, nothing happens
It’s possible that this is the same issue as the following:
Assuming it is the same, although this bug was recorded first, it would be convenient if further conversation could continue on this other thread, since there’s already been some discussion there.
